*SOLD* 2011 Mustang GT Racecar & Car Hauler Combo
Gidyupp
Post by Gidyupp » Mon Oct 24, 2022 2:13 pm
Car & trailer sold, thanks for looking.
Car & all spares = $20K
Trailer = $21K
Package = $39K
2011 Mustang GT 5.0, manual transmission, Brembo package. Original owner, 33,011 miles. COMSCC #44 SUPER-B
MORE PHOTOS HERE -->> https://photos.app.goo.gl/ZLmyUFy5cHJd8KP88
Car was converted to fully caged track car in 2017. Did two HPDE/time trial events per year, then did not run in 2020, 21 or 22 due to pandemic interruption and other priorities.
Never crashed or had any body work. NOTE: some photos show crack in windshield (from rock kicked up at track). Windshield has since been replaced with new.
Engine is stock, except for cold air intake, mufflers and custom tune. Last dyno (2018) showed 393 rear wheel horsepower and 373 rear wheel torque.
Car was used for HDPE & time trials, no door-to-door racing.
Car hauler was custom built in 2018. Has only been used for four events. Hauler is set up for camping at track with bathroom and bed. Water tanks and battery easily last 3-day weekend.
Selling as package deal, just need a helmet and you are ready to hit the track! Love the car, hate to see it go, but priorities changed over the last couple years and other hobbies have taken priority.
SAFETY
• Custom Built Roll Bar/Cage by Pipe Dreams Fabrication (COMSCC Member) Rochester, NH (.134 x 1.75 DOM (10ga.) main hoop/structure; .120 x1.75DOM for braces)
• OMP WRC XL driver seat
• OMP WRC passenger seat
• Schroth Driver 6-point harness - FLEXI 2X2 - Expires end of 2024
• Schroth Passenger 6-point harness – Clubman - Expires end of 2024
• Fire suppression system - Lifeline Zero 2000 FIA 4L Fire Marshall system. Release at tunnel and at A-pillar. Nozzles at drivers legs and engine bay
• Portable Halon Extinguisher with Drake Off Road quick-release mount
• Racequip drivers window net
• Simpson Center net
• Simpson fire resistant shifter boot
• Cartek GT-S Solid state master battery switch with switch on dash and A-pillar
• Switch and circuit for cool suit
DRIVETRAIN
• Torsen T2R 4:1 Bias racing differential
• Ford racing 3.31 ring & pinion gear set
• Blowfish Racing Shifter Support
• Barton Short Throw Shifter and Bracket Combo
• C&L Cold air Intake with K&N RE-0870 filter
• SCT SF3 handheld Tuner with custom tunes developed for road racing (full travel progressive pedal). Currently tuned for 93 octane pump gas. Comes with stock tune and various others.
• Borla “S Type” exhaust. OEM Cats still in place. Car sounds great, has passed sound at regional tracks (latest at Mt. Tremblant)
• Ford Racing Transmission Air Cooling Scoop FR# M-5025-MBR
• Ford Racing Finned Diff cover # M-4033-K, Tapped for cooling lines
• Afco differential fluid cooler and Tilton pump (not installed, but electrical circuit run)
• 2-QT Accusump Accumulator #24-026 (not installed, but circuit run)
• Moroso racing oil pan (not installed)
• Odyssey PC680MJT AGM Racing battery with custom mount
• Cartek GT #1068-116 Battery Isolator Unit
• Longacre Accutech oil pressure gauge (installed, needs final connection)
• Longacre Accutech oil temperature gauge (installed, needs final connection)
• Longacre Accutech water temperature gauge (installed, needs final connection)
• Blowfish Racing sound tube delete kit
BRAKES
• Ford Racing Brake cooling kit P/N M-2004-MB with ducts to front lower grill
• Front OEM Brembo calipers with Carbotech CTM1001- XP20 racing pads – One weekend use , 80% thickness remaining, 14” ventilated rotors
• Rear OEM calipers with Carbotech # CTM1082-XP12 racing pads - -One weekend use , 80% thickness remaining, 11.8” ventilated rotors
• Rear parking brake delete
• NAPA Gold ventilated rotors
• Stoptech stainless brake lines front & rear
• Motul RBF 600 brake fluid
SUSPENSION / CHASSIS
• Ford racing power steering rack
• Eibach 159# linear front lowering springs
• Eibach 126/193# progressive rear lowering springs
• Eibach 36mm front swaybar
• Eibach 25mm front swaybar
• Koni Sport (yellow) shocks
• Whiteline Adjustable Rear Lower Control Arms
• Whiteline Rear Lower Control Arm Relocation Bracket
• Whiteline Adjustable Panhard Bar
• Spohn Upper Control Arm W/ Del-Sphere Bushing SKU # M5-605-11
• Maximum Mustang Camber Plates - P/N MM5CC-5
• Maximum Mustang Bumpsteer Kit - P/N Mm5TR-2
• Ford Racing M-3075-RA lower control arms with ball joints
• Ford Racing front hubs with ARP high strength wheel studs - #M-1104-A
• ARP high strength rear studs 1/2"x20
• Moroso Racing open 1/2” x 20 high strength lug nuts
• Ford racing / Sparco steering wheel #M-3600-R
• NRG quick release steering wheel hub
BODY
• Ford Racing CS front fascia with stainless mesh panels
• Racing heater box / defroster
• Blowfish Racing Front Tow Hook
• Wiring harnesses stripped, de-pinned and rewired from firewall back, body control modules eliminated.
• PATS theft deterrent system bypassed, toggle switch start
• Airbags removed
• Custom carbon-fiber center console with
WHEELS-TIRES
• Set #1: BFG G-Force R1 DOT Slicks - 285/30ZR18 on 18x11" ET52 APEX EC-7 Wheels
• Set #2:Continental Wet 245/45R18 EC-WET on 18x10" ET43 APEX EC-7 Mustang Wheel (Purchased directly from Hoosier, same as Hoosier wets, but labelled for the continental race series)
• Set #3: Bridgestone Potenza RE-71R - 275/35R19 on 19” Silver OEM Mustang Wheels
• Set #4: Bridgestone RE-11 - 265/35R19 on 19” Black Ford Racing Wheels
EQUIPMENT
• Aim SOLO lap timer, with dash mount, hardwired with remote switch
• ReplayXD front facing camera, hardwired with remote switch
• Battery Minder AGM battery tender
• Car cover
• Pressure bleeder with billet master cylinder adaptor
SPARES / EXTRAS
• New in box (front) Carbotech CTM1001- XP20 racing pads
• New in box (rear) Carbotech # CTM1082-XP12 racing pads
• New set of front rotors
• Set of rear rotors
• Spare front wheel hub with studs
• Spare rebuilt font caliper
• Spare rebuilt rear caliper
• Assortment of front and rear caliper seals, clips, etc. to rebuild calipers
• Rolling transport box for above
• Original Traction-LOK differential with 3.73 ring & pinion
• 3.31 Ford racing ring & pinion set
• Various rear end spare seals, bearings and shims
• OMP Seat Slider
• Whiteline Transmission Brace
ENCLOSED CAR TRAILER
• 2018 Proline custom built all-aluminum car hauler
• 9,900# GVRW
• Dual 5.2K galvanized Dexter Torflex axles with EZ-lube hubs and 12” electric brakes
• 15” radial tires on galvanized wheels
• 16” on-center floor framing
• 5” x 48” beavertail with heavy duty rear ramp
• 54” Vee-nose with divider wall for bathroom with shower, toilet and sink
• Queen bed with powered lift
• Drop down table
• Camper-style door with screen door
• White vinyl finished interior wall paneling
• Sliding window, driver side
• All LED running lights
• LED interior lights
• LED side and rear loading lights
• Pop-up vent in car area
• Maxx-Fan vent in bathroom
• Epoxy floor paint in car area
• Grey Quadripple plastic floor in bathroom
• Framed for 21’ awning, passenger side
• 30 gallon grey and fresh water tanks in belly
• Thetford cassette toilet with externally removable 4.75-gallon black water cassette
• Spare 4.75-gallon black water cassette
• 6-gallon RV propane hot water heater
• 12V fresh water pump
• Stand-up shower in nose with Oxygenics head
• Proto tool chest, bolted in
• Moduline custom built all-aluminum cabinetry (base, two wall and custom electronics enclosure)
• Custom fabricated in-floor storage compartment
• Wall mounted TV on swing arm
• Rear maintenance area at beavertail with fluid holders, paper towel and glove dispenser, etc.
• Pull down insect screen to separate beavertail area from bed
• Deep-cycle marine battery
• Solar panel with charger
• Inverter and charger with external connection
• Anderson load leveling hitch with welded on mount blocks
• In-floor tie downs with frame hooks for car
Call Mark - (603) 234-5008
Mark Richards
2011 Mustang GT SB #44
Gidyupp
Splitting up package - FS: 2011 Mustang GT Racecar & Car Hauler Combo
Post by Gidyupp » Thu Nov 03, 2022 2:20 pm
Due to a lot of calls about just the trailer or car alone, I've decided to split the package if needed.
Trailer = $21K
Package = $39K
Trailer was used for 4 events. Current new price of trailer, as constructed, is $22K as empty shell BEFORE fitout (Epoxy floor, cabinets, tool box, bathroom, tanks, TV, queen bed, etc.)
Mark Richards
Gidyupp
Re: FS: 2011 Mustang GT Racecar & Car Hauler Combo
Post by Gidyupp » Fri Nov 18, 2022 3:48 pm
Car sold (again).
Trailer still available.
Mark Richards
SophiyaSofthearted
Re: Splitting up package - FS: 2011 Mustang GT Racecar & Car Hauler Combo
Post by SophiyaSofthearted » Tue Feb 28, 2023 5:37 pm
Trailer = $21K
Package = $39K
Trailer was used for 4 events. Current new price of trailer and best fat burner for men, as constructed, is $22K as empty shell BEFORE fitout (Epoxy floor, cabinets, tool box, bathroom, tanks, TV, queen bed, etc.)
Are this package is still available?
