1999 Miata Track Day or Race car
I have a 99 that I just caged. I installed a 16" Ultrashield RR seat, quick release Longacre steering wheel, window net, ARP wheel studs, new Brembo rotors and Hawk DTC60 pads all around, Koni Sports with adjustable spring collars w/2.25" Eibach springs, Eibach SM swaybars w/rod end links, Aluminum radiator, new header and stainless exhaust. I replaced the front frame rails as they were just starting to show signs of corrosion. This is a mid Atlantic car that has a Salvage title from a fender bender hit. I replaced hood, fender and bumper cover. Radiator support core was not damaged. 150K miles car. Replaced water pump and timing belt. It should be a great car for someone. No Hardtop though the cage was built for one to fit if you want. $6k OBO
