*SOLD!* 16' Open Trailer for sale
mattd
Post by mattd » Mon May 22, 2017 9:38 am
2004 Premier 16' open car trailer -
Some info:
https://www.trailersuperstore.com/shop/ ... -in-ramps/
I bought it new in 2004 from a local dealer in RI. It has been dead reliable that entire time - they farthest it has been in that time was The Glen twice, Mont Tremblant twice, Summit Point two or three times, Mosport once. It is a very plain and simple car hauler, but from a decent company. It has real springs (7k lb. GVWR.) It has good electronic brakes, mounted spare tire, bearings have quick lube fittings and are greased regularly and I put four new Goodyear trailer tires on it at the beginning of last season. All the lights work. I measured the width between the fenders at 77".
It has a small dent in the left fender (see pictures) from a gas station post which I kissed at 3 in the morning on the way to Summit. It rusted a little (surface only) and I sprayed it with primer to try and stop it - it could do with a better repair - but not totally necessary. Other than that it is in good shape with normal wear - some surface rust in a couple spots but nothing major. I added a lockable storage box to the front of it 2 years ago for tow straps and the like. The breakaway brake system likely needs a new battery.
I am selling as I recently purchased an enclosed trailer.
Matt Daniels
#44 SE - 2001 small red convertible from Japan made by Mazda
