shop compressor
Grippy
shop compressor
Post by Grippy » Mon Feb 27, 2017 2:07 pm
SOLD!
Gordon Andrade
#10 Super C MX-5
SEISAN
Re: shop compressor
Post by SEISAN » Mon Feb 27, 2017 4:47 pm
Looks more like a submarine to me.I would need a dock to fit it in.
not for me
BB
Re: shop compressor
Post by breakaway500 » Mon Feb 27, 2017 8:51 pm
How old is the tank? (does it have a build tag on it?)
Grippy
Re: shop compressor
Post by Grippy » Mon Feb 27, 2017 10:32 pm
Tank was built in 1978 according to the tag. It is in very good shape and didn't seem rusty at all. I think it was set up with an automatic drain before I got it. It has only had light use since, I don't use air tools much I guess.
The tag also says it is only 80 gal.
Gordon Andrade
#10 Super C MX-5
Re: shop compressor
Post by jeffw » Tue Feb 28, 2017 1:23 am
if i had 220v in the compressor room i'd be all over it.
jstan
Re: shop compressor
Post by jstan » Tue Feb 28, 2017 8:33 am
What are the dimensions? L x W x H
Grippy
Re: shop compressor
Post by Grippy » Tue Feb 28, 2017 9:43 am
It is approximately 60" long, tank is 20" diameter, maybe 5 feet high.
Jeff, if you plug it into two outlets you get 220v, right?
Gordon Andrade
#10 Super C MX-5
Re: shop compressor
Post by Stynger » Wed Mar 01, 2017 8:00 pm
jeffw wrote:if i had 220v in the compressor room i'd be all over it.
Have you looked at 110 to 220 power converter?
Re: shop compressor
Post by breakaway500 » Wed Mar 01, 2017 9:46 pm
Those converters aren't very efficient,especially on an old motor with magnetic starters. You could replace the 220v motor with a 110v modern one,but the amperage required will be beyond most existing 110v circuits,and the air output would be less (with greater electricity usage)
Juiced06GTO
Re: shop compressor
Post by Juiced06GTO » Fri Mar 03, 2017 6:35 pm
That is a pretty good deal for a shop compressor. I just picked up a used vertical 80 gallon for $400 a few months ago, but this one looks to have a much better compressor and motor on it. If I had a place to store it until I am done building my barn I'd come grab it so I could have one in the new barn and one in the main house!
2006 Pontiac GTO - Recovering Drag Racer....
Grippy
Re: shop compressor
Post by Grippy » Sat Mar 04, 2017 6:52 pm
SOLD!
Gordon Andrade
#10 Super C MX-5
