Four 15x9 Miata wheels (4x100bp) with 275/35/15" Hoosier R6s
Post by breakaway500 » Mon Jul 13, 2015 12:59 pm
I have four gently used 4x100mm bolt pattern (Miata and others) 15"x9" 949 Racing 6UL nickel colored wheels (+36mm offset and 67.1mm center hole) with four Hoosier 275/35/15" R6 tires mounted. Wheels and tires were bought new in 2010 (2010 dated) and used for two events and then have been stored in heated shop.
Wheels have only seen one set of tires and are true,with a couple of scrapes from mounting: These are tough tires to mount!
Tires are worn evenly with no flat spots (I had them on my 2004 Mazda Miata Mazdaspeed with abs brakes) One tire has some scuffs high on the sidewall on the inside where it made light contact with the left inner wheelhouse,before I corrected the problem (took out some camber) but is safe to use. Center caps are there..I never used them..but they are plastic,which never seem to stay put.
First $600 takes the stack.
I can bring them to the Thompson or Whiskey Hill events, or pick them up in central Ma. (Oakham) I'm not using the Miata for track so these are just collecting dust.
Users browsing this forum: Google Adsense [Bot] and 1 guest
