for a example NA Miata
if your car new had no power steering and AC . you would still have to adjust the classification point as if you removed them from the car your self  .
						clarify removel
Re: clarify removel
Modified steering rack from power assist to manual or manual to power assist is a zero point mod in the suspension section.
AC was a factory option on the NA Miatas thus you do not assess the removal of it in the engine section (just the weight removed).
Re: clarify removel
thanks I found it right after i posted it .
