I seemed to have lost my wedding band. I believe between changing the tires in the extreme hot weather in the afternoon of Friday at the garage bay near the pit entrance (by the lifts, side garage facing the track) and removing my work gloves to immerse a towel in the ice in a cooler the ring must have slipped out. This is the same areas where Mark, Sam and Bob where parked. I used Bob's spot to change my tires on Friday.
The wedding band is very unique: gold, very wide (about ¼ inch at top and tapering) with inscriptions inside. The outside also has a grooved shape of “infinity” throughout the wedding band.
I e-mailed the track as well.
I'd appreciated it if you could check your coolers if you left them in that garage as I was putting stuff there and using it to wet my towel to keep cool.
Tks,
Stephan
Lost wedding band at NJMP-Lightning event
Re: Lost wedding band at NJMP-Lightning event
Bummer! I hope it turns up.
Stephan,
Sorry to hear it. Hopefully it will show up. Pray to St. Anthony!
