T60 Roll Call
- modifiede30
T60 Roll Call
So I saw the T50 post to see who's running in that class, and being a returning COM member from several years ago, I was thinking it would be good to know who else would be running in T60 and what cars they're running. I'll be in a BMW M-Roadster (1998). I'd be interested to know who else is running a T60, and in what car - just so I know when I'm being passed........
1998 M Roadster - T70
Re: T60 Roll Call
Will you be changing your username to 'modifiede36' or 'unmodifiede36'?modifiede30 wrote:I'll be in a BMW M-Roadster (1998).
- modifiede30
Re: T60 Roll Call
Not possible - I guess that's a lesson learned - don't use a car as your user name if you can't use it for life.....
- modifiede30
Re: T60 Roll Call
I think its just a slow time of year for the forum, it will pick up soon though with the test day approaching. - Paul G.
- blindsidefive0
- Moderator
Re: T60 Roll Call
I'll be in T60. For those curious, here is how my car points out:
1997 BMW M3 - Showroom Assessment: 62.5 points
Engine: 0 points
Drivetrain: 0 points (rebuilt shifter: 0)
Suspension: 4 points (single adjustable shocks: 1, non-height adjustable springs: 2, poly control arm lollipops: 1)
Brakes: 0 points (new rotors, pads, and stainless braided lines: 0)
Exterior: 0 points
Weight: -4 (3335lb minimum weight - I'm adding a roll bar, and will go with a full tank of gas and spare tire, if needed)
Tire Compound: 8 points (BFG R1-S or Hoosier H2O)
Tire Size: -1 (225mm wide: -2, oversize tire brand(s): 1)
Total: 69.5
Engine: 0 points
Exterior: 0 points
Total: 69.5
Re: T60 Roll Call
Here are my details.
When I buy better tires I will probably dump the "go fast" shinny objects this car came with and take it back to a factory gear ratio. For now it assess at 67.7
Model Mustang GT
Factory Rated Crank HP 300
Factory Rated Torque 320
Showroom Base Weight 3555
Showroom Assessment Points 64.7
Category Assessment
Engine 2.0
Drivetrain 1.0
Suspension 0.0
Brakes 0.0
Exterior 0.0
Weight Reduction -3.0
Tires 3.0
# Total 3.0
Total Assessment 67.7
Classification T60
The points break down:
# Engine (2)
1 Reprogrammed Factory Trim (includes ROM chips) ECU, naturally aspirated engine
1 Non-Factory Trim/modified air intake before the throttle body
# Drivetrain (1)
1 Non-Factory Trim/modified final drive ratio
# Suspension (0)
0 Non-Factory Trim non-adjustable shocks/struts/dampers
# Brakes (0)
0 Non-Factory Trim brake pads or shoes
# Exterior (0)
# Weight (-3)
-3 (3705 - 3555 = 150)
# Tires (3)
3 Toyo RA1, R888 (255/40)
Model Mustang GT
Category Assessment
Engine 2.0
Drivetrain 1.0
Suspension 0.0
Brakes 0.0
Exterior 0.0
Tires 3.0
# Total 3.0
Classification T60
# Engine (2)
# Drivetrain (1)
# Suspension (0)
# Brakes (0)
# Exterior (0)
# Weight (-3)
# Tires (3)
Emilio
T30
1990 Miata
T30
1990 Miata
- modifiede30
Re: T60 Roll Call
Good to see the list growing. I'll post my assessment once I have figured out how I am going to configure things - right now most options put me at 69+ points so I don't have much wiggle room and I'm on street tires!
Re: T60 Roll Call
Showroom Assessment
Make Lotus
Model Elise
Factory Rated Crank HP 190
Factory Rated Torque 138
Showroom Base Weight 2006
Showroom Assessment Points 73.0
Touring Class Base Classification T70
Category Assessment
Engine 0.0
Drivetrain 0.0
Suspension 1.0
Brakes 0.0
Exterior 0.0
Weight Reduction -4.0
Tires -1.0
Total -4.0
Total Assessment 69.0
Classification T60
Make Lotus
Model Elise
Category Assessment
Engine 0.0
Drivetrain 0.0
Suspension 1.0
Brakes 0.0
Exterior 0.0
Tires -1.0
Total -4.0
Classification T60
Re: T60 Roll Call
Novice
Showroom Assessment
Make Mazda
Model Mazdaspeed MX-5 Miata
Factory Rated Crank HP 178
Factory Rated Torque 166
Showroom Base Weight 2529
Showroom Assessment Points 55.6
Touring Class Base Classification T50
Category Assessment
Engine 13.0
Drivetrain 0.0
Suspension 3.0
Brakes 0.0
Exterior 0.0
Tires -1.0
Total 11.0
Total Assessment 66.6
Classification T60
Showroom Assessment
Make Mazda
Category Assessment
Engine 13.0
Drivetrain 0.0
Suspension 3.0
Brakes 0.0
Exterior 0.0
Tires -1.0
Total 11.0
Classification T60
