Miata Coil Springs & Misc Parts
bhoss
Post by bhoss » Sun Feb 19, 2012 5:17 pm
Cleaning out the garage:
Mazda Miata Racing Coil-Over Springs
Lower and stiffer than stock springs – for comparison the Spec Miata springs are 700 lb/in front and 335 lb/in rear.
Eibach 8” Coil-Over Springs (2) – Miata Front Springs
Eibach 169054 0800.250.0750
2.50” inside diameter, 8” length, 750 lbs/in spring rate
In great shape – lightly used 1 season
$79.95 new/each – asking $75 for the pair
Eibach 8”Coil-Over Springs (2) – Miata Front Springs
Eibach H2009.065.T080
2.50” inside diameter, 8” length, 8 kg/in (447 lbs/in) spring rate
Eibach 7” Coil-Over Springs (2) – Miata Rear Springs
Eibach H180-065-T060 30,06
2.50” inside diameter, 7” length, 6 kg/in (336 lbs/in) spring rate
94/97 Miata Stock Brake Pads
Brand new (out of box) Monroe Dynamics SE DX635 $44.95 at CAP
Asking $25.00
SOLD!!!!!!!!!1990 –2005 Mazda Miata Competition stainless steel brake line kit - DOT approved - brand new
• Made in USA for 949Racing
• Stainless steel braided hoses
• Clear hi temp nylon protective sheaths
• Simple one piece hard line attachment
• Improved brake feel
• Everything you need for all four wheels included
This kit attaches directly to your factory hardline, unlike other kits that use a separate adapter. Always flush the entire brake system with a newly opened bottle of high quality brake fluid when installing new brake lines.
http://949racing.com/miata-brake-lines.aspx
New $94.99 - asking $70.00
Small Air Duct For Bumper Spoiler SPA-D107 – have 2
Spoiler or Small Areas. 4.5" Deep, 9.75" Wide
This is the Ram Air Brake Cooling Duct for limited space applications. Can easily be trimmed for BMW E-30, Spec E-30 Brake cooling applications. If you have allot of room look at the SPA-D100, if not this will keep your brake temperature down. Takes 3" Hose
http://www.discoveryparts.com/cgi-bin/s ... ng&pid=150
New $14.99 each – asking $15 for both
Oil Cooler Duct - SPA D110
Oil cooler duct that fits 10" x 8.5" coolers
7.79" Deep, 10.0" Wide
Takes 3" Hose
http://www.discoveryparts.com/cgi-bin/s ... ng&pid=153
New $19.99 – Asking $12.00
Large NACA Duct, Dual Hose
Computer Aided Design (CAD) and wind tunnel testing have been combined to produce these ducts. Attention to detail results in maximum air flow with minimal drag. They are molded from tough, high-impact clear or black plastic. An integrally molded flange (approximately .75" wide on most ducts) makes them easy to install in body panels, air dams or side windows. The outlet nipples are sized to fit our 3" air ducting hose. Approximately 10.5" long x 9" wide with flange. Black
https://www.pegasusautoracing.com/produ ... oduct=3629
New $23.99 Asking $15.00
Email bhoss47@comcast.net if you have any questions
Bill Hosselbarth
COM Secretary 2011
1994 Mazda Miata
#49 PC
