I know it won't rain this coming season,but just in case Sams magic doesn't work...
New Hoosier wets at 1/2 price
Not all sizes availabe.. https://www.hoosiertire.com/discontinuedtires.htm
Re: New Hoosier wets at 1/2 price
You going to get a pair of the 315/35R17's for the front Mark?
John F
#167 SA FFR roadster
I went with the 245's for the front of the Focus,and skis for the back..
rousespointer
Re: New Hoosier wets at 1/2 price - size ??
Is a Hoosier size 285/645R18 close to a size 285/30ZR18? I can't remember how to convert the numbers? What does the -O mean on the list?
The 645 tells you the diameter of the tire, which is 25.4" (645mm / 25.4mm per inch = 25.4"). I don't know exactly how to calculate the aspect ratio from that data, but a call to Hoosier will get you squared-away in no time. My guess is that it's between 30 & 35.rousespointer wrote:Is a Hoosier size 285/645R18 close to a size 285/30ZR18? I can't remember how to convert the numbers? What does the -O mean on the list?
The math is really ugly in the tire world thanks to the combination of metric and imperial measurementsdradernh wrote:The 645 tells you the diameter of the tire, which is 25.4" (645mm / 25.4mm per inch = 25.4"). I don't know exactly how to calculate the aspect ratio from that data, but a call to Hoosier will get you squared-away in no time. My guess is that it's between 30 & 35.rousespointer wrote:Is a Hoosier size 285/645R18 close to a size 285/30ZR18? I can't remember how to convert the numbers? What does the -O mean on the list?
But by my calculations the profile of 285/645R18 would be 33, so in the tire world it could be rated as either a 30 or a 35 profile.
A = ((Di - Ri) x 25.4) / (Wm x 2)
Where:
A = Aspect ratio
Di = Diameter in inches
Ri = Wheel radius in inches
Wm = Section width in mm
To go the other way:
Di = (Wm x A x 2 / 25.4) + R
^Very impressive,Chris!
Yep, 9th grade alegbra, LOL.
Wish I could remember the years that followed, I hear they taught us some cool stuff.
225-245/45/R17 "Continental Grand Am Series Tires" for $147ea...what a damn DEAL! Ack, if only I could run these on my street car!
