Cleaning up the garage and found the following that I will not be using:
AeroCatch Flush Mount Panel Fastener
AeroCatch Model 120-2000 – Black – new in plastic case
Purchased new from Pegasus
http://www.pegasusautoracing.com/produc ... t=3038-001
New $74.99 – never opened $50.00
Momo Hub Adapter – model #C4509
Ford 65 to 73 Mustang Momo Steering Wheel Hub Adapter
Specially design steering wheel adapter to be use with MOMO racing steering wheels. The MOMO steering wheel adapters use a unique design that incorporates a collapsible steel center section for added safety, attached to a splined aluminum base that matches the spline on your steering shaft. This is covered by a plastic bellows to give it a professional finished appearance.
http://www.racinglab.com/momo-hub-34.html
New $88 - never used $40.00
NRG 2.5 Steering Wheel Quick Release – Gen 2.5 – Black
6 Holes base design works with NRG, MOMO and Sparco steering wheels
Another upgrade utilizing all the features of the NRG's Second Generation Quick Release Systems with the added benefit of a flared ring. This allows much easier release for the steering wheel by providing added leverage and grip onto the pull ring. Perfect for race applications where the use of gloves are required. The NRG Innovations has developed the Next Racing Generation in quick release. These new units feature many options that conventional Ball-Lock quick release systems do not offer including specially designed raised sections to prevent the hub from stretches, a self locking mechanism for ease of use and safety functions, and as always, a variety of different colors and color combinations. Made from highest quality aircraft aluminum or powder-coated stainless steel for maximum durability, these units are meant to last, remain stylish, as well as have functional usage. http://www.racinglab.com/nrg-qr1-srk-250bc.html
New $120 – never used $60.00
Cobra Automotive Rear Brake Scoops – fiberglass
Part of the 100-2500 Rear Drum Brake Cooling Kit 1965-73
The air scoops mount to the rear axle housing with clamps and 3” hoses connect to the backing plate with bolt on hose adapters. There is no ground clearance issues because the air scoop moves up and down with the suspension. Does not include brake hose or backing plate adapter. Asking $50.00
Cobra Automotive - Mustang Tie-Down Kit – Rear Only.
Universal fitting rear end eyelets clamp around the axle housing and can be positioned
in multiple places. Tie down hooks snap into place allowing proper towing angle of straps.
Part of 100-999 1964-66 Mustang kit Asking $50.00
Small Air Duct For Bumper Spoiler SPA-D107 – have 2
Spoiler or Small Areas. 4.5" Deep, 9.75" Wide
This is the Ram Air Brake Cooling Duct for limited space applications. Can easily be trimmed for BMW E-30, Spec E-30 Brake cooling applications. If you have allot of room look at the SPA-D100, if not this will keep your brake temperature down. Takes 3" Hose –
http://www.discoveryparts.com/cgi-bin/s ... ng&pid=150
New $14.99 each – asking $15 for both
Single NACA Duct – black 10” x 7” Asking @10.00
Double NACA Duct – black 10” x 9” Asking $10.00
Bill Hosselbarth
bhoss47@comcast.net
508-533-8936
Misc Parts for sale - Part II
Bill Hosselbarth
COM Secretary 2011
1994 Mazda Miata
#49 PC
COM Secretary 2011
1994 Mazda Miata
#49 PC
