eclip5e
Post
by eclip5e » Thu Jan 13, 2011 7:48 pm
I don't see anything in the rules about hybrids.
With a 1.5l engine and a hybrid system, would I be correct in thinking that 122hp of hybrid power from the new Honda CR-Z could be competitive in ST4?
Because now that my Impreza is toast. I'm finally emotionally stable enough to start considering my options.
Ron. A
Post
by brucesallen » Fri Jan 14, 2011 12:23 pm
Oh no! I guess we have to deal with it. And the electric golf carts coming out. Nate: what are the kilowatt to weight ratios? Do we handicap based on battery chemistry? LiMh bumps you up? Or we could outlaw them all-- like nitrous.
Post
by jlwhorf » Fri Jan 14, 2011 12:43 pm
brucesallen wrote: what are the kilowatt to weight ratios?
Should be pretty easy, 1 kilowatt = 1.34102209 horsepower
nateh
Post
by nateh » Mon Jan 17, 2011 10:48 am
I would go with Jonathan's formula for now. See how it goes, then revise as necessary. Battery capacity might be an important complicating factor, but it's hard to guess a priori.
I'm looking forward to having the hybrids. Another bit of technical coolness!
- Administrator
Post
by TroyV » Mon Jan 17, 2011 11:34 am
http://www.crzforum.com/forum/general-d ... -dyno.html
The dyno numbers, in concert with a sub 2700lb weight and a good suspension could make it formidible in SSC/ST4, though with those power and weight numbers one could argue that the car belongs in SSB/ST3 if the NB and NC Miatas are there with roughly the same numbers.
I think it could be a very interesting choice Ron. It certainly could change a lot of minds about the potential of hybrid technology......in a track car.
subsonic
Post
by subsonic » Mon Jan 17, 2011 4:10 pm
Why is it toast Ron? Mine is a pancake.
eclip5e wrote:I don't see anything in the rules about hybrids.
#217 SPB
