Glen to have showers!!
Post by brucesallen » Wed Dec 08, 2010 2:21 pm
Re: Glen to have showers!!
Post by 6PAK72 » Wed Dec 08, 2010 10:49 pm
YaHooo!
grovefromnh
Post by grovefromnh » Thu Dec 09, 2010 9:01 am
Will they have credit card machines for using the showers?
30+ yr member
SEISAN
Post by SEISAN » Thu Dec 09, 2010 5:05 pm
Anticipated Credit card charges
Cold water and a hose - $5.00
Hot water and a hose - $10.00
Hot water and a hose with body wash - $15.00
Hot water, rubber hose, body wash and a clean towel...... Priceless.
John F
Post by John F » Fri Dec 10, 2010 9:22 am
The most noticeable improvement will be the addition of permanent grandstands in the final two turns of the 11-turn circuit, another next to the pedestrian bridge, and one at the outside of the first turn, a 90-degree right-hander at the end of the front straightaway.
This will cure people of taking Turn one too hot :shock: So much for a big run-off
John F
#167 SA FFR roadster
jakesrodshop
Post by jakesrodshop » Mon Dec 13, 2010 4:26 pm
always have had showers, just not in paddock. go thru tunnel heading out, take a right, then first left and down in the camping fields theres a brand new building with 4 nice showers, used them the past 2-3 years.
