1.6 Miata Parts. Many left over parts from development of HPDE and ITA race Miatas.
Aluminum flywheel $95.00
ACT pressure plate & 4 puck clutch. In good condition. $95.00
OEM flywheel Pressure plate and clutch $75.00
ITA legal Cylinder head. Planed to increase compression ratio .5, port matched to intake manifold, competition valve job. Head & matched Intake. $750.00
ISC Racing Services Header, used 2 weekends $125.00
Racing Exhaust system, Boig header, exhaust pipe with Springfield muffler $200,00
Tuned racing exhaust system and muffler. From header flange back. $120.00
Coil over springs two 400# springs two 750#springs $70.00
ITA legal Cylinder head. Planed to increase compression ratio .5, port matched to intake manifold, competition valve job. Needs valves checked as I believe there may be a bent valve. Paid $3K and ran for one year. $250.00
Spare brake caliper, Front $ 15.00
Newly built 1.6 engine. Bored and balanced. Carrillo Rods. Wiseco Pistons. New Oil Pump. New water Pump. New timing belt. Head work done, ported, matched, Stainless steel valves and valve strings. Matched Intake included. Alternator, starter, coil pack, cam sensor, fuel rail w/ matched injectors. $2,400.00
Spare brake rotor. $20.00
Spare Oil Pump / Low miles $10.00
Spare water pump / $10.00
CPU with rev limiter bumped 500 RPM, with Greddy Piggyback computer for better tuning. $250.00
Miata Racing Parts
Miata Racing Parts
Re: Miata Racing Parts
Hi do you still have a diff? what shape is the clutch presure plate in ? Phone? thanks
Soory the diff has been sold.
The pressure plate is in good condition.
603 434 6607
603 434 6607
Hello, is the "Racing sway bars and bushings, stiffer than spec Miata. $100.00" still avaliable?
