1.6 Miata Parts. Many left over  parts from development of  HPDE and ITA race Miatas.
Aluminum flywheel									$95.00
ACT pressure plate & 4 puck clutch. In good condition.					                $95.00
OEM flywheel Pressure plate and clutch 						                $75.00
ITA legal Cylinder head. Planed to increase compression ratio .5, port matched to intake manifold, competition valve job. Head & matched Intake.        $750.00
ISC Racing Services Header, used 2 weekends						$125.00
Racing Exhaust system, Boig header, exhaust pipe with  Springfield muffler 			                $200,00
Tuned racing exhaust system and muffler. From header flange back.			                $120.00
Racing sway bars and bushings, stiffer than spec Miata.					$100.00
Coil over springs two 400# springs two 750#springs					                $70.00
ITA legal Cylinder head. Planed to increase compression ratio .5, port matched to intake manifold, competition valve job. Needs valves checked as I believe there may be a bent valve. Paid $3K and ran for one year.						$250.00
Spare brake caliper, Front        $ 15.00
Newly built 1.6 engine.   Bored and balanced.  Carrillo Rods. Wiseco Pistons. New Oil Pump. New water Pump. New timing belt. Head work done, ported, Stainless steel valves and valve strings. Matched Intake included. Alternator, starter, coil pack, cam sensor, fuel rail w/ matched injectors.											                                               $2,400.00
Spare brake rotor.									$20.00
Spare Oil Pump / Low miles								$10.00
Spare water pump / 									$10.00
CPU with rev limiter bumped 500 RPM, with Greddy Piggyback computer for better tuning.	               $250.00
													Miata Parts Sale
Miata Parts Sale
						Re: Miata Parts Sale
How does the CPU/ECU compare with what the rest of the ST4 Miatas are running?
I'd be interested in the head and the ECU.
Thanks!
Thanks!
				escortracer
are the sway bars still available?
thanks
						thanks
