Not sure of the COM Class this would fall into, as it is essentially a stock motor with Weber side drafts.
1983 BMW 320i
SCCA FSP solo/ BMWCCA track car
2009- 1st place SCCA North East Region Divisional Champion- 2nd place SCCA National Tour-SCCA Mo-Hud Region points leader in Street Prepared
2008- 2nd place SCCA National Tour NE- 3rd Place SCCA Pro Tour- 2nd Place North East Division Championships
Vehicle Mileage: 219,300mi
Engine- Mileage : 95,000mi
1.8L
Header/ Top End Performance muffler system
Twin -Webber 40 DCOE Side Draft Carburetors
Baffled Oil Pan
Steel Left Side motor Mount/ new rubber mounts
Accel Coil
Suspension- Ground Control Coil Over 600lb F 500lb R
Koni Shocks Custom Valved Single external adjustable -front
Double external adjustable-rear
Ground Control Racing Camber Plates
21mm Front Sway Bar
3 Position Rear Sway Bar / urethane links
Urethane Bushings in rear trailing arms
Stainless Steel Flex Brake Lines
New Front to Rear Fuel and Brake Lines
New Master Cylinder
Body- Good Solid
Full 8 Point Roll Cage- 1 ½” DOM Tubing .120 wall tube
Battery Relocated to RR of trunk
Quick Release Steering Wheel
Kirkey Seat
6 Point Harnesses
Comes with
Wheels- Set of 4 aluminum 15”x 7”
Set of 4 steel 13”x 8” diamond racing
Set of 4 aluminum 13”x 5 ½”
Set of 4 basket weave 13”x5 ½” aluminum
1 Complete engine - rebuildable
2 1.8L heads
Miscellaneous parts
LF Fender
Spare throttle cables
4 Front Strut Assemblies -2 / springs(stock)
2 transmissions 1 good, 1 need input shaft
Spare Flywheels
Spare Alternator
2 Spare 200lb. coil over springs
2 Spare 350lb. coil over springs
Spare Sway Bars front and Rear
Xtra stock shocks front and rear stock
Spare clutches
Extra sway bars and links
Extra brake pads and calipers
Extra front hubs
Good Rear Trailing arms LS and RS
Fuel Pressure Regulator and Guage
More Photos http://picasaweb.google.com/91rs13/Bruc ... directlink
Contact Bruce Kosakoski -- 518-674-8816 or bkbbmw@gmail.com
$4495 OBO -- Located in Averill Park NY
( about 30 mnin east of Albany)
