Post
by breakaway500 » Sun Oct 18, 2009 11:27 am
This is the factory radiator out of my 2004 Mazdaspeed Miata,with 23k miles. It has never seen a winter and has no corrosion.It does NOT leak.NO broken tabs etc.It does have some handling marks on the cooling fins,but nothing that will affect anything.Guaranteed to be water tight.I had to move to a larger capacity radiator with the addition of the new turbo upgrade.I can bring this to NHMS5 or it can be picked up in Oakham,Ma. $90. Next stop, Ebay!
MiataSteve
Post
by MiataSteve » Sun Oct 18, 2009 1:07 pm
By any chance, do you know the interchange with other years? As in, will it bolt up to a 90?
Post
by breakaway500 » Sun Oct 18, 2009 1:55 pm
I believe it fits all the NA and NB cars. I can give you measurements if you would like.
FredRoy
- Rookie Driver
Post
by FredRoy » Mon Oct 19, 2009 10:38 pm
AFAIK, radiator size is not an issue, but NA and NB cars use different lower mounting tabs... You can probably sort it out, but I do not think that it is "drop in".
Fred
Post
by breakaway500 » Tue Oct 20, 2009 8:00 am
It drops in to 99-05 Miatas and some bracketry repositioning for 90-97s. Def does not fit 98's.
Post
by CP » Thu Oct 22, 2009 12:09 am
I've got 2 good stock 99 Miata radiators for $35 each if anyone needs one.
Post
by breakaway500 » Thu Oct 22, 2009 6:56 am
Hey! Start your own ad!
