Hi,
I'm new to COM & find no mention of a requirement (as some clubs have) for a pre-event tech inspection by a "qualified mechanic". Can I assume that COM, like SCDA, doesn't require more than the event-day trackside inspection?
Thanks, Doug
Pre-Event Tech Inspection
Re: Pre-Event Tech Inspection
Hello & welcome to the forums!
You are correct. COM does not require a pre-inspection or sign-off by certified shop. We hold our own tech inspection each morning. Tech sheets are supplied to participants when they sign-in at registration. I believe our tech sheet is scheduled to be added to our website. This will probably happen within a few weeks, but as always, I reserve the right to be wrong.
Thanks for the quick reply, Will; I look forward to running with COM!
- Doug
- Doug
