The valve lash got adjusted extremely carefully, the entire secondary electrical has been replaced and checked, air filters are new, the fuel filter and pump replaced, carb diaphragms replaced, jets set...you get the idea. One change at a time.
The engine is running MUCH smoother, but here's the issue:
When I retard the distributor timing (Still has a vacuum advance in place) to 34btdc, the idle is terrible, and accelleration from 1,000 rpm at any pedal pressure causes a bog. BUT, there is NO missing (detonation??) above 4200rpm, and the engine revs powerfully to 5500rpm.
BUT, the engine temp indicates hot all the time. A lasar thermometer indicates 190f at the sending unit, 155f at the bottom of the radiator. Not good for the TR.
When I advance the distributor timing to about 44btdc, the engine idles really smoothly, does not bog accellerating, and pulls very strongly to about 4200rpm, where it begins to miss. It misses all the way to 5000rpm, and the power just dies off at 5000, does not pull to 5500. As for temp, the cockpit indicator is at neutral, and the lasar reads 166f at the sending unit, 123f at the exit side of the radiator.
Mfr. spec is 34btdc, though with the 276deg duration cam, and 1.55 roller rockers I know I've moved that off the spec. Pistons are .03 over, deck is dropped .02, spec compression was 9.5:1, with the Carillo pistons I think I'm up around 10.6:1. I know full race engines running 13:1.
Anyone have ideas? Spark plug heat range? Richness?
Give up and drive a Honda?
BTW, Lee and Stephan, I have 5-points installed
Thanks, see you in KaBek,
