Longacre Hot Lap in-car Timing System
velozmedia
Post by velozmedia » Wed Feb 04, 2009 7:18 am
Now you can see your lap times - instantly!Where dash space is limited - display is in smaller enclosure.
Includes compact display, receiver, transmitter, harness and instructions.
An infra-red transmitter mounted at trackside automatically triggers the In-Car Timer with 100% accuracy each and every lap - no 'thumb' errors. Use the Double Range transmitter where access to the edge of the track is limited. Standard transmitter works up to 60 feet. (Transmitter requires 4 C-cell batteries not included. Receiver requires a 9V battery also not included.)
Drivers see your lap times as they happen
Adjust your driving line to find the fastest time
Easy to install & remove
60 lap memory with easy recall
Transmitter can be mounted inside or outside track
Great for Karts, Formula Cars, etc.
RETAIL: $240.00
On Sale: $150 + $10.00 FedEx shipping inside US
