ST Taped or coated headers
Shawn624
Post by Shawn624 » Sat Sep 27, 2008 11:18 pm
What do you think of the following rule change:
X. STREET TOURING
6. Aftermarket headers may be used. Headers may be coated or taped. Muffler use is required, but type is unrestricted. Exhaust must exit behind rear wheels and outside the body. Exhaust tubing size is unrestricted. Catalytic converters must be used in cars originally
The heat from my headers is wreaking havoc under the hood. Aside from the higher underhood temps, I'm cooking wires. At Mosport, an emmissions hose from the headers melted the side of a valve cover causing oil to spill out on a certain hard left downhill turn.
Shawn Sweeney
97ish Miata #99
Post by breakaway500 » Sun Sep 28, 2008 5:42 am
Sounds fine to me.Anything that potentially helps keep oil off the track.(was that at the bottom of turn 2? :shock: )
nhsilversti
Post by nhsilversti » Sun Sep 28, 2008 8:02 am
even with my headers wrapped i melted the the lower part of the radiator fan assembly and completely melted/burnt the wiring for the fans. i cant imagine what it would have done if there was no wrap at all.
DanDarcy
Post by DanDarcy » Sun Sep 28, 2008 12:54 pm
Shawn , C4 Vettes are noted for high under hood temps stock. I think you will still have a problem with wrap, but I don't see a problem with allowing it as long as a pnahard bar is also allowed :!: Craig Herrick crashed his Mustang 2 years ago at Mosport because the axle moves arround so much with out the panhard that it broke the control link. I have already replaced to control links that have torn out the bushings and bent the mounts. Luckily mine have not snapped apart yet .
Shawn624
Post by Shawn624 » Sun Sep 28, 2008 10:09 pm
Sounds like those Mustangs are just dangerous Dan. I'd stay away from them. :)
This is not really an underhood temp problem as it is a matter of protecting some of the components that come near the headers and emissions pipes. I've melted a throttle cable housing, burned some plug wire protective sleeves, and recently the valve cover.
Shawn Sweeney
97ish Miata #99
Re: ST Taped or coated headers
Post by StephanAlfa » Mon Sep 29, 2008 9:08 am
Shawn624 wrote:What do you think of the following rule change:
X. STREET TOURING
What you are merely doing is tranfering the heat to another location so bear in mind on the type(s) of heat insulation you may need further down in the pipes.
In SS I cannot do this because you are creating a "performance" effect by keeping things "cooler" in the engine compartment.
But using tapes will only transfer heat dissipation to somehwere else. So better get some protection under your seat :shock: :lol:
Post by jlwhorf » Mon Sep 29, 2008 9:44 am
Another thing to consider. If you are using steel tube headers, wrapping them will dramatically reduce the life of the header. I knew people who would replace wrapped headers each season on their stockcars. Instead, you might want to make heat shields to protect the items that are vulnerable to heat.
Jonathan
Post by brucesallen » Mon Sep 29, 2008 11:22 am
jlwhorf wrote:Another thing to consider. If you are using steel tube headers, wrapping them will dramatically reduce the life of the header. I knew people who would replace wrapped headers each season on their stockcars. Instead, you might want to make heat shields to protect the items that are vulnerable to heat.
Jonathan
Totally correct, Jono. I learned the hard way.
enjoythemusic
Post by enjoythemusic » Mon Oct 06, 2008 1:32 pm
Agree, heat shields are good as is having the headers Jet-Hot coated inside and out.
Enjoy the Track,
Steven R.
http://www.EnjoyTheTrack.com
mossaidis
Post by mossaidis » Mon Oct 06, 2008 5:41 pm
X. STREET TOURING
I think something to the effect of "To properly divert exhuast heat, the use of heat shields, coatings, wrappers, etc is unrestricted from the exhaust header gasket on" works.
Shawn624
Post by Shawn624 » Tue Oct 07, 2008 8:25 pm
X. STREET TOURING
It sounds like heat shields are the way to go where there is room to put them without simply making them heat conductors. So an effective rule would allow for heat shields, coating and wrap.
Shawn Sweeney
97ish Miata #99
MMiskoe
Post by MMiskoe » Sun Oct 19, 2008 1:05 pm
If the rule already reads that an 'aftermarket' product can be used, why do you need a rule change to allow it to be coated or wrapped? Some headers can be purchased w/ coatings. "Aftermarket" does not specify how many hands are involved in its production/ preparation prior to installation, it just offers something other than OE to be used. Sounds unlimited to me.
Matt
cuda6666
Post by cuda6666 » Sun Oct 19, 2008 1:54 pm
MMiskoe wrote:If the rule already reads that an 'aftermarket' product can be used, why do you need a rule change to allow it to be coated or wrapped? Some headers can be purchased w/ coatings. "Aftermarket" does not specify how many hands are involved in its production/ preparation prior to installation, it just offers something other than OE to be used. Sounds unlimited to me.
Matt
Why? Because these are the ST rules :lol:
