looking for BIG garage with AC power to rent for 2 weeks
nhsilversti
Post by nhsilversti » Wed Apr 02, 2008 6:17 pm
i am in search of a big garage space to rent so i can build a new trailer. i have all tools needed including the welder. the welder requires a 60 amp 220v outlet that i can put in if needed. how big you may ask, the bed of the trailer is going to be 24' not including the tongue and the last 4' being a beaver tail.
i expect it will take me 2 weeks total to make, this may vary if the space being used is a long drive away. the closer the garage the faster it can be done. i really only need to do the frame, axles, fenders,tongue and lights to be able to tow it away, i can finish the rest at my house outside including the painting.
ted
RJ
Post by RJ » Fri Apr 04, 2008 5:56 pm
Where in southern, NH are you?
Post by Mark Swinehart » Fri Apr 04, 2008 6:37 pm
"i am located a little west of nashua. ted"
That would be the Milford area.
nhsilversti
Post by nhsilversti » Fri Apr 04, 2008 8:15 pm
thats correct, milford area it is.
i found a place last night but it needs a LOT of cleaning to make it usable. im going to run with that unless something better comes along.
thanks
ted
RJ
Post by RJ » Fri Apr 04, 2008 9:10 pm
AH gotcha. I'm just over the border in maine. If you were on the coast you could use mine.
