I'm parting my old track car to make way for my Locust 7 project. The following are all available.
Eibach Aluminum Strut Brace - Front- $150.00
No-name Strut Brace - Rear- $75.00
Delrin Diff Mount - Press-in Style - $50.00
New OEM Motor Mounts - $65.00
Random Alarm - BMW sticker but no instructions - $25.00
Random Relays - $10.00
528eA ECU - seta - $150.00
Distributor cap and rotor - only 10k on them - $25.00
Urethane Diff Mount - bolt-in type - $75.00
Stock Subframe Mounts - new - $30.00
ContiTech Timing Belt Kit - $20.00
New 'is' Valve Springs - stock - $75.00
New Graf water pump - $35.00
Complete Head Gasket Kit - $70
Cheesy White Gauge Faces - $10
Miscellaneous Seals - $2 each - let me know what you need
Cheapo stock front pads -new I think they're FrictionTech- $10
Idle Control Valves - $25 each
New Head Bolt Set - $50
M30 AFM with Filter - $60
Front 'is' Valence (local pick-up only) - b.o.
Center Vent Gauge Panel - Semi Carbon Fiber - $50 (gauges not included)
IE Stainless Steel Headers - not yet fixed - mid length - unequal $250.00
Reconditioned 'is' head, new guides, valves, seating job $750.00
New 292 CatCam $275.00
New CatCam Perf Valve Springs $125.00
New Coilover Springs - 550lb/600lb $250.00
Konig Wheels - Imagine in bronze diy powder coat $350.00
Stock Basketweaves $150.00
Corbeau Seats - Forza - (local pick-up only) $325.00 set
Corbeau Bases $50.00 each / $75 for the set
Rear Subframe cleaned and painted with camber adjustment tabs installed $300.00 – subframe bushings have been removed.
2.5l Block $50.00
ETA Crank $50.00
Bored TB $100.00 – pending sale
ECU Chip - Alpina Copy $150.00
ECU Chip - Stock $25.00
ECU Chip - ETA Modified for 027 stroked engine $150.00
ETA Tranny $150.00
RX7 Calipers $25.00
Lightened stock IS flywheel 10lb - $200.00
7mm wires $75.00
19# injectors (8) $50.00
New uninstalled 22mm IE Front Bar $150.00
25mm Master Cylinder $75.00
If you have any interest, let me know at dcteague@comcast.net or post here. Any reasonable offers will be considered for the above.
BMW E30 Parts Sale
- modifiede30
