Mont-Tremblant Pics/Video
austaz
Re: Mont-Tremblant Pics/Video
Post by austaz » Wed Jun 19, 2013 9:12 pm
Here's my TT vid, I can't get the vid's to sync up but I have my data overall next to chads on my PC and there are some obvious places to gain time by using all the track at turn in, maybe a bit slower on entry and earlier on the gas.
T1,2,3 - I should be carrying a lot more speed and loose 0.8s.
T4/5 - I make up about 0.2s with a different line, but there should have been more time by getting up on the curb out of 4.
T7 I setup about 2ft in from the track edge (this is common for me as I like the buffer in case the car shifts under braking but I have to learn not to do it) and turn in a little early with less speed.
T8 again not right on the edge of the track but I make up 0.3s very different line, then loose 1/2 of it back by T10 with about a 0.5mph lower exit speed.
T10 and 11 I should have been going back to 3rd, Chad gains a lot by accelerating between the corners.
T11 different lines but very similar times.
T12 again not right on the edge of the track on turn in and not using enough brake given the uphill, need to slow it down a bit more on entry to get on the gas more.
phpBB [video]
blindsidefive0
Post by blindsidefive0 » Thu Jun 20, 2013 8:06 am
Here's the 2nd to last session on Day 1, with the checker in the middle of the session. These were over a dozen hot laps trying (and mostly failing) to hang with Pete and Mick. This is probably the single most fun session I've ever had, ever. Unfortunately, like the other AIM videos, I don't have throttle/brake. Although I have an OBDII car, the ECU is too old to keep up with the data capture.
0:00 - Troy
1:00 - Pete
1:20 - Mick
4:45 - Chad with his new ride-on grass mower
7:00 - 2012 Driver Champ
12:35 - #47 Miata communicating with smoke signals
14:00 - Pete decides to ruin Mick's lap to let me catch up; thanks, Pete!
16:40 - Chad, again, this time with NOS up the back straight
phpBB [video]
Post by Stynger » Thu Jun 20, 2013 9:40 am
Great vid, Nick.
Thanks for sharing. 8)
Post by wizzman » Thu Jun 20, 2013 9:59 am
Did that red Miata lift for you at 7:00?
blindsidefive0
Post by blindsidefive0 » Thu Jun 20, 2013 10:09 am
wizzman wrote:Did that red Miata lift for you at 7:00?
It's too hard to tell with those things...
dradernh
Post by dradernh » Fri Jun 21, 2013 7:15 pm
This is my TT video. I tend to be conservative during TTs, and this one was no different - the throttle and brake bars will show where time was left. It was nice to be back on a track where you can stretch out a bit.
The 20-disc SuperTrapp that I added to the resonator and muffler already on the car slowed the car a bit in the fast sections, but it was better than being black-flagged out of there like I was at a BMW event right after Mosport last year.
The speed shown is low by ~3 MPH, and the wheel is off ~10° to the right.
phpBB [video]
Post by Mark Swinehart » Fri Jun 21, 2013 8:01 pm
Doug -
Nice video of my car.
Thanks -
Post by jeffw » Fri Jun 21, 2013 9:55 pm
I gave RaceRender a try. It's pretty decent, though I've got some issues with the data from my logger. It doesn't display any laptime for the first lap.
phpBB [video]
naschmitz
Post by naschmitz » Sun Jun 23, 2013 10:14 am
jeffw wrote:I gave RaceRender a try. It's pretty decent, though I've got some issues with the data from my logger. It doesn't display any laptime for the first lap.
Try going into the Configure settings on your data file. Hit the [Manually Set Start/Finish Point] and adjust the tolerance on the heading, or X or Y to see if you can fix that.
Bert Schmitz
paseobeater
Post by paseobeater » Fri Jun 28, 2013 2:37 am
Stynger wrote:RACOON, good times! What do you run for tires?
thanks!
I'm running 225-45r13 hoosier r6
I surprised myself with my old high school car this weekend.
I will post a video as soon as I can get it converted to put on youtube! :D
RACCOON!
77.3 WHP TOYOTA PASEO
blindsidefive0
Post by blindsidefive0 » Tue Aug 20, 2013 12:14 pm
Since I know he's going to return the favor, I present to you your COMSCC 2012 ST4 Class Champion, Miata Cup Champion, Japanese Cup Champion, and 2012 Overall Driver Champion, Dave Wittmer taking the fast way around T1-2-3...
phpBB [video]
Also, same spot on the track, this guy almost got me killed:
