mont-tremblant FUNNNNNNNNNNN !!!!
Re: mont-tremblant FUNNNNNNNNNNN !!!!
Post by 962porsche » Sun Jun 14, 2009 2:02 pm
i can reinstall the carpet it just glues to the floor there is no sound pading and only waid 18 lbs . its the rear pick up points on the roll cage . its 5 1/4 inchs past the rear wheels 5 is the max . if i had the bars come down less than 5 1/4 inchs then is on the sheet metal over the fuel tank .AND THATS NO GOOD ! and removing the carpet in no way makes up for the weight of a full cage ? the car is on par with ST4 classed cars .
zip4zat
Post by zip4zat » Sun Jun 14, 2009 3:45 pm
WillM wrote:Joe, you aren't kidding!
During open track, when I was behind you and Mick, I totally lost track of your car. As I crested the slope at T9 I thought you both had totally run away. I almost almost soiled my race suit when your brake lights went on going into T10. I wasn't that close, but your gray car was totally invisible in the mist.
I think I even had my running lights on, because it WAS so hard to see. I generally just follow the spray, cause at least I know that there IS pavement in there... hopefully...
Joe Lu
#24 ST1 STi
