Rule Proposal: Harnesses
jadams
Additional Harness Questions
Post by jadams » Fri Feb 08, 2008 2:01 pm
Do both harnesses (driver and passenger), need to be the same kind? If I have no intention of ever having a passenger, do I really need to updated the unused harness? Seems like a waste of money to me.
Can anyone recommend a good harness that is HANS compatible? (2" shoulder belts)
Joel
Joel Adams
1995 Pontiac Trans Am
Class T80
Post by jlwhorf » Fri Feb 08, 2008 2:30 pm
Pull your passenger seat out.
Jonathan
jadams
Post by jadams » Fri Feb 08, 2008 4:47 pm
Can I legally do that in SPA?
Joel Adams
Class T80
cuda6666
Post by cuda6666 » Fri Feb 08, 2008 6:05 pm
Put in a plastic baby seat like I did (or so Grove alleges) :roll:
Post by jlwhorf » Fri Feb 08, 2008 6:47 pm
Street Prepared automobiles must comply with section VI, then any modifications are permitted while observing the following restrictions:
14. The passenger seat may be removed to allow the installation of a "Petty Bar".
It will stiffen the unibody and you won't have to worry about a second set of straps.
Jonathan
Post by offcamber09 » Fri Feb 08, 2008 11:27 pm
Jonathan
Could you guys kindly stop giving Joel ideas that could make him faster!
Joel what they mean is that petty bar should be full of lead- for added strength- yeah that's the ticket.
jadams
Post by jadams » Sat Feb 09, 2008 2:00 am
I was wondering what a Petty Bar is.....so it is a huge lead filled tube, huh? That sounds cool. In order to offset that, I am considering inflating my tires with Hydrogen! :shock: I bet that would be sweet!
On another note, my new suspension started to arrive today! :D New Koni shocks. The swar bars arrive tomorrow....and my new springs should be in next week. I like Scott's idea from the other post.....you can't add up costs! I stopped keeping track a long long long time ago. :roll:
Joel Adams
Class T80
Post by chaos4NH » Sun Feb 10, 2008 12:18 pm
Here is the answer to the question about Scroth harnesses that are DOT approved:
SS and ST cars may use any DOT, SFI, or FIA approved harness.
