Don't forget to disconnect those sway bars!JackFFR1846 wrote:It's wicked easy to use the scales in the tech shed. Disconnect all sway bars. Roll the front of the car on the scales. Read and record the right then the left. (you can do left and then right but then have to convert to metric). Next, roll the car forward so only the rear is on the scales. Record the right then left (or left and right and convert to metric).
(note: if you don't understand the humor, you should not be weighing anything)
scale at the track
Re: scale at the track
