Post
by breakaway500 » Mon Sep 15, 2008 8:06 am
As long as you have rules and regulations,there will be controversy about them. Like Stephan said at the beginning of this thread;
"the BEST way to get this addressed is to SUBMIT your reasons for changes or GO to the COM meetings."
Some rules may seem to bias one make over the other,but I am sure it was not intentionaly conceived, and only requires that someone request a review of that particular regulation.
Sometimes the rules are vague, and require a request for clairification.
To play by the rules requires some careful preparation as other competitors are watching.
...or as cuda6666 suggests,move to a class where (almost) anything goes.
except cutting of fenders
Post
by brucesallen » Mon Sep 15, 2008 11:30 am
Fenders? Racers with fenders are wussies.
Ditto windshields.
Post
by breakaway500 » Mon Sep 15, 2008 11:33 am
I'm with you Bruce
lou m
Post
by lou m » Tue Sep 16, 2008 9:45 am
Chris, I believe a rule change for this particular car is reasonable. Go ahead and write it up. I will be at the rule change meeting and can present it. I know it's a long drive from NY.
Lou
Post
by jlwhorf » Tue Sep 16, 2008 12:05 pm
chrizz28 wrote: Interesting sidetrip... a LT1 F body can run LS1 F body brakes, but needs to change the spindle. No brackets are required so this would be legal??
I would not feel guilty calling the spindle, a component of the braking system. I feel that the spirt of ST is that you are allowed to unbolt a braking system from another car (from the same manufacturer) and bolt it to yours. When I ran in ST, I swapped early 70's Impala brakes on my gen 2 Trans AM.
It maybe more economical to fab together mis-matched parts, but allowing this opens the door to rules creep. Parts swapping has always been a hot topic when classifying between ST and SP. But with the current safety rules, the only penalty going from ST to SP is the 3 timed hot laps.
Jonathan
chrizz28
- Rookie Driver
Post
by chrizz28 » Sat Sep 20, 2008 11:17 am
lou m wrote:Chris, I believe a rule change for this particular car is reasonable. Go ahead and write it up. I will be at the rule change meeting and can present it. I know it's a long drive from NY.
Lou
thanks... where do I find info on writing it up and submitting this?
2000 Camaro Z/28 #728
- Administrator
Post
by Mick » Sat Sep 20, 2008 12:02 pm
Chris,
I'm working on creating a rules change request submission form for the website. It should be posted by Monday. In the meantime you can write up your thoughts and I'll let you know when the form is ready.
Thanks
chrizz28
- Rookie Driver
Post
by chrizz28 » Sun Sep 21, 2008 8:47 pm
Mick wrote:Chris,
Thanks
thank you!
