Mont Tremblant event ... FANTASTIQUE!!!
I need a faster Alfachaos4NH wrote:Faster than I want to go!jakesrodshop wrote:no prob sam.
what kind of speeds can be had on the long straight? 140-150? with 500 hp?![]()
My Speed 3 peaks about 125 and I think the Subie STIs check out around 135-140.
That about right Keith? Raj?
I don't know what my top speed at Mosport will be with the current setup - the last time I was there, the ECU was shutting the car off at 120mph - the speed limiter hadn't been reset. 135 should be no problem. A '69 Camaro isn't particularly aerodynamic, though 500hp will certainly help. The problem with the back straight at Mosport is you start it off from close to a dead stop and 2/3 of it is uphill. I'd think whatever you did at Tremblant would be about the same.
-Keith-
SPB116
SPB116
yeah my new front splitter and rear spoiler laid down will help, i imagine 135-145, as it has good tq and pulls hard from 3000-6800 rpm
i think i was doing around 125 or so at mt
on a side note a my car weighs about 3200 with driver
That has been my experience (not that any data from a Miata has any relevance to 500 HPctkag wrote:The problem with the back straight at Mosport is you start it off from close to a dead stop and 2/3 of it is uphill. I'd think whatever you did at Tremblant would be about the same.
BTW, you guys estimating speeds with your speedometers know that stock speedos are wildly optimistic, right? Most of them overstate speeds by at least 5 MPH around 100 MPH.
Of course, top speed is also kind of beside the point compared to lap times, which is really what matters. Except no one at home or work ever asks what my lap time was. All they ever seem to ask is "how fast did you go?"
ST4 Miata #62
ST4 Miata #62
