Who's ready for NHIS-1???
SSC it is then!
I heat cycle my tires in Route 3 NH (Everett Pwy in NH) between exits 1 and 8 and part of 93/89 depending on ambient temp.
There is a parking lot I know that I sometimes check the tires (for grip of course) ... I also measure the angle of body roll
and determine there is absolutely nothing I can do about that. :dontknow: other than pray it will stick to the ground [-o<
Any bonus points for painting your car with NHIS turn 1 safer barrier? Or using the wall to correct a camber problem that otherwise couldn't be adjusted?skid vicious wrote: Also we plan on challenging for the 'Most badly dented car in COM' trophy this year.
Also, what the heck did you do to end up in SPA with your BMW?
- MiataSteve
This might be of help for your First Day.. http://www.nasaproracing.com/hpde/firstday.htmlBob Shannon wrote:But can you ever really be ready for your first day on the track?
