- Administrator
Post
by WillM » Thu Feb 01, 2007 10:27 am
dinoracer wrote:And by the time I'm done I will have spent $ 1500, which I should have spent in the first place on some AFR aluminum heads.....
I love to learn things the hard way
Well Tom, that sux. Sorry to hear about your continued misfortune. Seems that problems like these tend to snowball.
That said, if you've already learned that you should have bought some AFR aluminum heads in the first place, I would suggest doing so now. Don't chase bad money with good. Of course, it is much easier for me to spend your money.
Post
by offcamber09 » Fri Feb 02, 2007 9:31 am
Tom, they are not the hottest aluminum heads- but I use them- the GT40x turbo swirl heads are under $1000 I believe. I don't know what's worse- what you are going through or not having any time to even look at your car...on second thought at least my problem is cheaper for now- good luck.
ctkag
Post
by ctkag » Fri Feb 02, 2007 12:55 pm
So Tom, wouldn't it just make more sense to pick up a set of aluminum heads now while you're halfway (in cost) there?
-Keith-
SPB116
Post
by dinoracer » Sat Feb 03, 2007 2:34 pm
offcamber09 wrote: they are not the hottest aluminum heads- but I use them-
If I'm going to move up in the SPA pecking order, I have to pass you
...so I better get any advantage I can find!
