ST class intake rule clarification
xstar
Post by xstar » Wed Oct 12, 2005 4:22 pm
ST Rule regarding intakes:
(Original)
5. A. Any air cleaner may be used. Original carburetor or fuel
injection throttle body (or OEM equivalents with same flow rate) must
be used. In all cases, intake manifold must remain stock as delivered.
(Proposed)
5. A. Any air cleaner or intake (up to the throttle body for naturally aspirated vehicles and up to the turbo/supercharger compressor inlet for forced-induction vehicles) may be used. Original carburetor or fuel injection throttle body (or OEM equivalents with same flow rate) must be used. In all cases, intake manifold must remain stock as delivered.
The intent is to clarify the rule regarding section of the intake from the air cleaner/filter to the throttle body. The original rule does not specify, thus leaving the decision up to the steward interpretation of the rule.
(Updated to cover forced-induction vehicles)
Re: ST class intake rule clarification
Post by Stynger » Wed Oct 12, 2005 4:55 pm
IMO this is a good update. It doesn't change the rules intent, but clarifies the wording.
The interpretation of this rule has been varied, I'm sure those effected would back such a rule change.
kfoote
Post by kfoote » Wed Oct 12, 2005 5:57 pm
Agreed. To me, this seems like one of those rules changes that won't require much debate, and should pass easily.
Post by WillM » Wed Oct 12, 2005 7:06 pm
I agree. This rule should make it through, especially since the current rule is vague. Stock class says air filter is open, ST says air cleaner is open.
I interpret 'cleaner' as what we commonly consider 'intake'.
IE: My vaccum cleaner has a filter inside of it.
Bravo, X! =D> [-o< =D> [-o<
MiataSteve
Post by MiataSteve » Thu Oct 13, 2005 7:40 am
I too would like to see this change. Does the proposed rule leave a loophole for forced (super or turbo charging) induction installed forward of the throttle body/carburetor?
Just playing Devil’s Advocate.
boltonite
Free HP, Zoom Zoom!
Post by boltonite » Thu Oct 13, 2005 8:22 am
Here's a video of how to be creative or stupid with an open intake rule:
http://videos.streetfire.net/Player.asp ... CA9564&p=0
Right-click on the video and zoom to full-screen to get the full effect.
Fred F
BrakeL8r
re: forced induction
Post by BrakeL8r » Thu Oct 13, 2005 10:08 am
MiataSteve wrote:I too would like to see this change. Does the proposed rule leave a loophole for forced (super or turbo charging) induction installed forward of the throttle body/carburetor?
Rule X.6.C covers this case (at least for ST):
C. Turbocharged and supercharged cars will be moved up one class
from the normally aspirated version, unless otherwise specified.
--Michael
ST4 Miata #176
Grippy
Post by Grippy » Thu Oct 13, 2005 10:47 am
This should be a no brainer as it is just a clarification of the existing wording. It seemed pretty clear to me but others had questions. Let's get this put to bed.
therooster
TURBO CLASSIFICATION
Post by therooster » Thu Oct 13, 2005 5:24 pm
" C. Turbocharged and supercharged cars will be moved up one class
from the normally aspirated version, unless otherwise specified."
This only applies to OEM/Factory installed turbo/supercharger. If you add an aftermarket kit onto your car you instantly get transported to a very SPecial place.
Chris A.
mossaidis
Post by mossaidis » Thu Oct 13, 2005 6:05 pm
Thank you for the clarification. Then would allowing boost modifications create too much of an unfair advantage for turbo cars?
therooster
Post by therooster » Thu Oct 13, 2005 6:40 pm
I thought that boost controllers were discussed at either the rules meeting last year or the year before. I quickly looked for my notes but I am a little disorganized at the moment and can not find them. Am I crazy or does any on else remember that meeting?
Chris A.
xstar
Post by xstar » Thu Oct 13, 2005 6:46 pm
mossaidis wrote:Thank you for the clarification. Then would allowing boost modifications create too much of an unfair advantage for turbo cars?
This proposal is only meant to clarify the intake before the throttle body. Boost modifications for forced-induction vehicles is a separate issue.
See the following thread for boost modification discussion.
http://www.comscc.com/forums/viewtopic. ... 04de3d#623
xstar
Post by xstar » Thu Oct 13, 2005 10:30 pm
Rule change submitted.
xstar
Post by xstar » Fri Oct 14, 2005 10:43 am
Updated original proposal to include forced-induction vehicles.
Included further clarification to close a loophole that would allow possible intercooler modification on forced-induction vehicles in ST.
ctkag
Post by ctkag » Fri Oct 14, 2005 7:57 pm
Well, I'd like to see another clarification too around the intercooler - allowing the intercooler hoses to be changed to the commonly used silicone hoses. These are post turbo but pre throttle body.
-Keith-
-Keith-
SPB116
