ST4 and other 1.6 Miata guys Dyno #'s
Georgethefierce
Post by Georgethefierce » Tue Dec 26, 2006 4:32 pm
If you've had your car dyno'd what did it put down?
it would be helpful if you could name the type of Dyno and if the numbers were corrected or not
thanks
J
07 IT7
Angrypork.com
84 RX-7
Flatout Motorsports
Miata numbers
Post by Flatout Motorsports » Tue Dec 26, 2006 5:50 pm
I PM'd Jason to see if these would be relevant, he said sure...
All done on a DynoJet corrected. (New England Dyno; Douglas, MA)
Stock 1.6's with cone filter, lightweight Mobil 1, OEM manifold and Springfield Dyno exhausts - with a tuned AFM - all go around 108-110 at the wheels, 99-100 ft/lbs.
"Pro" 1.6 SM motors with all the legal tricks and a tuned AFM go around 116-120 at the wheels, 105 ft/lbs.
SCCA IT-legal 1.6's built to the max go around 125 at the wheels, 108 ft/lbs.
My dead-nuts legal IT 1.8 has run a best of 133 at the wheels, 121 ft/lbs. Progammable FI should bring that to about 136-138whp this winter.
Edit - these are not industry marketing numbers - these are our numbers.
Andy Bettencourt
Flatout Motorsports
www.flatout-motorsports.com
Post by WillM » Tue Dec 26, 2006 7:51 pm
Wow, I would kill for numbers like that! :shock:
102 at the wheels @ NE dyno about a year ago.
I believe torque was at ~98 lb-ft.
Stock engine, aftermarket intake, header, exhaust.
Flatout Motorsports
Post by Flatout Motorsports » Tue Dec 26, 2006 9:42 pm
WillM wrote:Wow, I would kill for numbers like that! :shock:
Will,
I am betting there is 3-5whp in AFM tuning left in your car. Nick is the man on that stuff. If you want me to let you know when mine hits the dyno for the ECU, we can get you in on it.
Andy Bettencourt
Flatout Motorsports
tmak26b
Post by tmak26b » Tue Dec 26, 2006 11:17 pm
100rwhp stock on dynojet, 93 with 85K miles
137rwhp with just a stock greddy kit on stock everything
155rwhp with an exhaust
182rwhp at 10psi
200rwhp at 12 psi
Georgethefierce
Post by Georgethefierce » Wed Dec 27, 2006 8:00 am
tmak26b wrote:100rwhp stock on dynojet, 93 with 85K miles
182rwhp at 10psi
200rwhp at 12 psi
CHEATER!!!
J
07 IT7
Angrypork.com
84 RX-7
bhoss
Post by bhoss » Wed Dec 27, 2006 9:14 am
1994 Miata with 97 engine
Headers and intake
113.23 hp 107.92 max torque - at Douglas dyno
Bill Hosselbarth
COM Secretary 2011
1994 Mazda Miata
#49 PC
mossaidis
Re: ST4 and other 1.6 Miata guys Dyno #'s
Post by mossaidis » Wed Dec 27, 2006 10:19 am
Georgethefierce wrote:If you've had your car dyno'd what did it put down?
thanks
I know you asked for ST4... and it seems everyone is throwing just about every 4 cyl on here. So here it goes...
92 Honda Civic Si. Full ST engine trim: CAI, DC 4-1 header, SMSP cat, Bosal cat-back, UR street pulley, Mobil 1 5w-30.
122.3 whp w/ 92 pump on a Mustang MD 1750 dyno (Red shift motor sports)
that was a year ago, probably less now after all my COM abuse.
Post by WillM » Wed Dec 27, 2006 11:31 am
Flatout Motorsports wrote: Will,
Hey Andy,
Sounds cool, keep me posted!
jimalley
Is that all?
Post by jimalley » Wed Dec 27, 2006 8:14 pm
Will,
You have got to have more up your sleeve than that :roll:
Don P
Post by Don P » Wed Dec 27, 2006 8:54 pm
Your right Jim -
If I still had my Miata I'd want my (Will's) motor back :D
Don
(gone back to my stang days :lol: :D )
Post by WillM » Thu Dec 28, 2006 11:48 am
Well, the motor DID, but not in my car.
Not sure why, but my dyno results were down compared to the dyno plot from when the engine was in Don's car. My guess is that it has something to do with the different intake/header/exhaust/cat and difference in parasitic loss between the two cars.
While my peak numbers weren't as good, I had better low-end torque (~7-8 lb-ft) up to about 4500RPMs, where the two curves started to match. I believe the backpressure from the catalytic converter and longer intake tract setup in my car helped the lower-end numbers.
These pulls were done at the same dyno as Don's (NE Dyno/Douglas Dyno). In fact, as we were leaving the dyno early last year, I believe the FlatOut crew was arriving with a batch of cars.
Took a look at the dyno results last night, and I was wrong. We started at 102 and finished with the strongest ST/IT legal pull of 104hp. We did get up to 106 hp, but that was with an RX7 flow meter, which was only on the car during dyno testing. Not legal for ST or IT.
Numbers are honest!
Wait a minute - reading between the lines - it seems that both Don and Jim have either sold or are selling their Miatas. That's crazy! Those cars are the poster-children of what a beatifully kept Miata should look like! I hope they have gone to COM members. Either way, best of luck with the new rides, gents!
tmak26b
Post by tmak26b » Thu Dec 28, 2006 11:49 am
Turbo should have been standard on the Miata, 100hp is a joke.
182rwhp at 10psi
200rwhp at 12 psi
CHEATER!!!
BrakeL8r
Post by BrakeL8r » Thu Dec 28, 2006 3:29 pm
Don P wrote:Your right Jim -
Don
Don't leave us hanging Don. Are you really going back to American Iron? Details, we want details.
Michael
ST4 Miata #176
mossaidis
Post by mossaidis » Thu Dec 28, 2006 7:10 pm
tmak26b wrote:Turbo should have been standard on the Miata, 100hp is a joke.
182rwhp at 10psi
200rwhp at 12 psi
CHEATER!!!
This guy is fitting right into COM... Did you know that COM also stands for Club of (NA) Miatas?
