All Aluminum Enclosed Aluminum trailer FS Price lowered
cmm3
Post by cmm3 » Sun Dec 29, 2024 3:37 pm
Price Lowered to $13,500 or BRO
Link to over 50 pictures here; https://photos.app.goo.gl/tZS7FixtEkzoDYcy5
One owner purchased new on 2/8/2016 and customized to owners’ specifications during pre-purchase factory visit
Trailer box is 18 feet long to the beginning of the V-Neck front section which adds another 4 feet 3 inches. Total length of enclosed trailer area is 22 feet 3 inches with the tongue extending beyond the enclosure. The V-nose and this length was specifically chosen to provide for lower weight, easier towing with greater maneuverability and less susceptibility to buffeting and swaying.
The base fully aluminum trailer was built by Pro-Line Trailers essentially hand crafted at their facility in Milton NH,
The base trailer is:
Model number CRHL816
VIN number 1P9BE2321GM489181
GVW 7000#
Color Victory Red
Trailer weight 2700 lbs
The base trailer offers the following:
• 52” V-Nose
• 6’6” Interior Height
• Dual 3.5k Dexter Torflex Axles
• EZ Lube Hubs
• 10” NEVR Adjust Brakes
• HD Ramp Door w/spring assist
• White Vinyl Finished Walls
• Ventline Popup Roof Vent with screen
• 7 way round trailer plug
• Car Hauler ramp door transition flaps
• Floor on 16” center
Customization and Additional items:
• Side Main 32”x68” door mounted on V-Nose instead of the side of the trailer, offers access to front of trailer, tools, work area with car in
trailer and easy tie down of car
• 5” X 48” Beavertail allowing loading and unloading of lowered cars without scraping
• 54”X48” Escape Door allowing drivers side door of loaded car to be fully opened allowing easy exit and entry of car
• 2 each wall mounted tire racks mounted over hood area of loaded car providing clear storage area for 8 tires
• Internally mounted spare tire and wheel
• 15’ Retractable Awning provides shelter from sun or rain
• 2 each 5000# stabilizer jacks allows car to be loaded onto trailer without it being connected to a tow vehicle (Not Recommended)
• Led Light Bar mounted over rear door opening
• 32”x16”x13” Double Door wall mounted cabinet
• Gray 3/4 “ Quadripple Flooring including ramp
• 9 each LED interior Dome Lights
• E-tracks on walls
• Fueling door factory installed post purchase allows fueling of car while in trailer
• 4 each front 2 each rear 5000# Recessed D-rings to tie down car
Owner installed upgrades included in the sale:
• Custom 2pc Ramps made from ¾” Marine Grade plywood allowing for ultra-low cars to load without the front end hitting
• Wall mounted bracket to store ramps out of the way with car loaded
• Wall Mounted Nitrogen Gas Tank Regulator
• Ceiling mounted retractable Hose Reel for Nitrogen
• Bulldog 3000# winch mounted in V-nose with separate battery mounted in custom aluminum cradle, allows winch to easily be removed and
used elsewhere if needed. Battery is charged off of tow vehicle
• Two high density LED Lightbars to light ramp, used for backing trailer up at night and as work lights
• Anderson anti-sway weight distribution hitch assembly
• Floor mounted brackets to secure floor jack (jack not included)
• Door Mounted storage shelve
• Wall mounted diamond plate locking helmet storage cabinet
This is a beautiful lightweight trailer that tows fantastic. The Anderson weight distribution hitch was highly recommended by the trailer manufacturer as the only one of its type that also reduces sway and allows the trailer to be backed up without disconnecting.
The floor has been raised under the tire area with ramps that match the floor with front wheel stops that allows the driver’s door on my significantly lowered car to fully open without hitting the door sill.
The area under the white wall mounted cabinet is designed to accommodate a 30” wide rolling tool chest with draws secured with the included ratchet strap to the wall E-tracks https://www.harborfreight.com/30-in-5-d ... 70698.html (not included)
The trailer has less than 5k miles on it since new. The wheel bearings have been greased annually and it has 4 new HD trailer tires on it with less than 1000 miles on them
The price of materials and these trailers have risen significantly since I purchased it. The base price of a well-constructed all aluminum trailer without any of the additional items included will far exceed the asking price of this one.
This is a opportunity to purchase a fully outfitted custom all aluminum enclosed trailer and save thousands of dollars in the process.
Will sell as described above with everything included as shown in the pictures for $13,500 or BRO
Thanks for looking
