2006 Lotus Exige Cup 240 race car
Post by brucesallen » Sun Aug 22, 2021 5:52 pm
Glen After 2nd Practice Run vlow res.jpg (60.62 KiB) Viewed 31133 times
Lotus Sport, the motor sport division of Lotus Cars Ltd., developed two higher performance versions of the 2006 Model Year Lotus Exige, the Lotus Exige Cup and the Lotus Exige Cup 240, both developed for track use straight out of the box.
The Lotus Exige Cup cars are based on the new 2006 Model Year Exige and are completely track ready sports coupes with uprated clutch, sports exhaust, adjustable suspension, uprated brakes, limited slip differential, switchable traction control, a T45 steel roll-over hoop and A-Frame with harness mounts, fuel and ignition kill switches and a fully plumbed in fire extinguisher system. An FIA approved 6 point roll cage is a no cost option.
The Cup 240 uses a supercharged and intercooled high revving 1.8 litre four cylinder engine producing 243hp (181 kw). This vast amount of extra power and torque mean that the cam change between the low and high speed now takes place at around 4000 rpm, giving a smooth and linear surge of power from 4000 rpm all the way to the maximum 8300 rpm. The Roots-type Eaton M62 supercharger is run from the crankshaft, and has an integral bypass valve for part load operation.
Price $49,900
This car is #13 of 15 made in 2006, has 9319 miles on the odo, and has received the following upgrades for speed and track reliability:
12/2015 New built engine- EIBACH VALVE SPRINGS stronger valve springs and FERRERA VALVES
Valves, work by Krugspeed
12/2015 Replace Accusump with Moroso racing oil pan. New aluminum oil coolers. Oil pump
2020 BOE 300 tune
2020 Rebuilt transmission with altered third and fourth ratios for better race match
2020 Fidanza race clutch and light flywheel
12/2015 Aluminum radiator to replace plastic. Remove heater
2015 carbon fiber splitter
12/2015 Wheel studs instead of bolts
12/2015 Quieter FEATHERLIGHT FREEFLOW Racing muffler with lower dB to meet most HPDE track sound limits.
2021 Carbotech pads, floating front rotors, Hoosier A7 tires. Brakes done very recently, have not had break-in yet.
Cool-suit setup
Second set of wheels with Hoosier H2O rain tires.
2021 Garmin Catalyst race coach and recorder ($1,000)
https://www.supercars.net/blog/2006-lotus-exige-cup/
http://www.diseno-art.com/encyclopedia/ ... p_240.html
Bruce Allen bruce@brucesallen.com East Kingston, NH
Re: 2006 Lotus Exige Cup 240 race car
Post by brucesallen » Mon Aug 23, 2021 5:55 pm
price set too high. $44,000
Post by brucesallen » Wed Aug 25, 2021 4:02 pm
Post by brucesallen » Thu Sep 09, 2021 9:40 am
car has been consigned to Kim Baker at vintageracecarsales.com
In the castle in chester, Ma.
castle small.jpg (63.71 KiB) Viewed 30675 times
Post by brucesallen » Thu Sep 16, 2021 4:41 pm
Post by brucesallen » Wed Oct 13, 2021 11:18 am
SOLD
Post by paultg » Fri Oct 15, 2021 11:00 pm
Congrats Bruce. Any idea if the new owner is local and will join any COM events? - Paul G.
Post by brucesallen » Sat Oct 16, 2021 11:21 am
a newbie from Long Island. apparently never been on track. He was looking into Palmer's last school day. Through my broker I suggested COM, but we have no more events this year.
Post by wizzman » Wed Oct 20, 2021 10:58 am
You at least left a COM flyer in the glove box right?
Post by brucesallen » Wed Oct 20, 2021 11:34 am
... and my lap videos of this year on my Garmin Catalyst
toejam_nh
Post by toejam_nh » Wed Oct 20, 2021 1:08 pm
Glad you were able to sell it! Solid deal. I was seriously considering it but then I thought about what the conversation would have looked like with my wife LOL.
You are missed, Bruce. I valued your direction as my very first COM instructor.
Cheers!
Vince Collins 003
2003 Nissan 350z SB
Post by brucesallen » Thu Oct 21, 2021 11:46 am
very difficult to convert to street. Factory cage, suspension, brakes, no cat, etc.
