Video Thread - Palmer clockwise (Remlap)
Here's by best lap from 06/20/2021
Re: Video Thread - Palmer clockwise (Remlap)
Very nice! What tires were you on? I'm really interested in what min speeds people are seeing.
We'll have the data depot up soon so people can link their data in these posts if they want to share.
Dan Durusky
Mazda RX8
Mazda RX8
Here's my vid
149.210 on lap 3
T70, 2014 Cayman S, Yoko A052s
Looking at the vid, I feel I'm still not on the gas as much as I should be. The first lap was a bit lazy with the throttle and wonder if its because the tires were cold resulting in like 27psi pressures and felt sloppy. On lap two I bobbled somewhere and gave up the lap to save the tires and it came together better on lap 3.
I was faster last year in T60 trim (148.
I assumed the difference was temperature and the A052s greasing up in the heat, but I did a quick look at the data last night and I actually lost all the time in T2 where I was simply going too slow. T2 is my nemesis, CW and CCW. gah.
I welcome all comments, especially ones saying to buck up and step on the gas more authoritatively.
149.210 on lap 3
Dan Durusky
Mazda RX8
Mazda RX8
Here's a couple of time trial laps of mine from this weekend. I feel there is a lot of time for me to make up here. First turn from straight (14?) I feel I wasn't driving deep enough before braking, always felt I could take that uphill faster. Any other suggestions other than get a faster car?
Vince Collins 003
2003 Nissan 350z SB
2003 Nissan 350z SB
My TT run. Sorry the sound didn't record, external mic didn't hook up to the GoPro...
First timed lap starts at ~2m in, the first 2 minutes are the out lap. The first timed lap was the fastest.
I made some early mistakes on the 2nd lap, so I backed off to save tire temp for the third one (and I knew the first lap was decent). I don't know if this is good strategy or not, this was my first TT.
I'm still a novice, so I'd certainly appreciate any input on what I could improve. Some things I noticed (and Dan pointed out the day before too):
- I'm bleeding too much speed from 14 -> 13 and doing a downshift here. Dan said I should leave it in 4th (and get the down shift in the braking zone into 12) and looking at the video I totally agree.
- Could have gotten on throttle a bit earlier in 12, given I clipped the inside of the apex on 11.
- I think grabbing 2nd in 9 is faster, but the upshift to third in 8 is at a time when the car gets light so I was being conservative / safe.
- I go on then back off throttle in 8 some, the car can hold WOT there pretty sure.
- Into 7, I tried a few different lines. Mid track seemed okay here, I think I should brake a bit later and trail brake more to turn the car in. Use the uphill to scrub the speed more instead of as much brake. I was back on the throttle before the up hill really gets going, which tells me I was braking too early.
- 2nd might be faster in 7 as well, but I have to manage inside front wheel spin in second if so.
- My throttle commitment was good after I got turned into 7, WOT all the way to braking zone into 5.
- Lifted / broke too early for 5 I think. I really wish I had brake inputs.
- I struggled with a line through 5. Tried a few over the weekend and really they didn't feel much faster either way. I'd love some input here.
- barely touch the brakes to get the car to turn into 4. Then WOT as soon as I could. Here's another spot that 2nd is probably faster. I also feathered the throttle, poor throttle commitment and I ended up having plenty of track out so I didn't need the partial lift.
- Good commitment in 2
- Got the car turned into 1 and back on the throttle early.
It would be incredibly useful to know if i'm wrong in some of my comments and if I also missed things. I'm still learning and really appreciate the input.
Brandon Ganem
#105 Mazda RX8
#105 Mazda RX8
The advice I always give for time trials – Don't think about laps. Execute each corner to the best of your ability until you see a checkered flag.
The panning effect on your camera is cool but I find it makes it more difficult to judge what the car is doing in relation to your steering input.
Thanks appreciate the advice! I'll certainly remember it for the next one.Mick wrote: ↑Wed Jun 23, 2021 6:46 pmThe advice I always give for time trials – Don't think about laps. Execute each corner to the best of your ability until you see a checkered flag.
I hate the panning effect - I think it's something the gopro does because of the video stabilization. I'll try to disable it for the next event. Going to try and get the camera lower next time too. The mirror blocks a lot at that angle, but it's as low as I could get it with the gear I brought to the track.
Brandon Ganem
#105 Mazda RX8
#105 Mazda RX8
Users browsing this forum: Ahrefs [Bot], Baidu [Spider], Majestic-12 [Bot], Semrush [Bot] and 1 guest
