SOLD
SOLD
Post by dtlemoine » Mon Jan 06, 2020 3:29 pm
Summary
Considering a few options for the COM 2022 season. Car is a multiple-class winning car built for COMSCC Time Trials, holds class records in T50, T60, SD. Car currently runs in SD, could also slot in towards the top of T80 on current setup, middle of T70 on Nittos/RE71R, or top of T60 on 300 tw summer tires.  A swap back to the M52 cams would remove ~8 Touring points from engine assessment.
Built and maintained by Wile Motorport. No longer street legal - built for Time Trials & HPDE; very good safety gear, however does not have full cage for W2W racing. Driver and passenger belts were new for the 2020 season. Shocks were also rebuilt at the factory and upgraded to their latest valve design.
Clean title, formerly registered in MA as street car. Car is straight, but does have it's fair share of zipties; never involved in contact with a wall, barrier, or other vehicle.
Engine
  • M52 motor, S52 cams, M50 manifold
  • Kassel custom tune
  • Cold air intake with headlight vent
  • Refreshed bearings in 2019
  • Rebuilt head in 2019
  • A/C delete
  • VAC dual valvespring / retainer kit
  • S54 oil pickup
  • Welded oil pump nut
  • Steward water pump
  • Mishimoto radiator
  • Aftermarket OE-equivalent exhaust, no risk of failing sound anywhere
  • Removed heater core (Bimmerworld front defroster installed)
  • Bimmerworld dual fuel pumps
  • Dyno'd at 211hp/193tq to the wheels on dynojet
Drivetrain
  • Rebuilt diff 3.73 gears with 3-clutch LSD - 2019 (diffsonline)
  • Rogue Engineering diff cover
  • Rebuilt bav auto driveshaft - 2019
  • New BMW half shafts - 2019
  • OE wheel hubs & bearings - 2019
  • E36 M3 Calipers
  • PFC 08/11 pads
  • Front OE M3 Euro-floating rotors
  • Rear OE M3 rotors
  • Stainless brake & clutch lines
  • Bimmerworld wheel studs
  • Bimmerworld "Group N" motor mounts
  • Solid transmission mounts
  • Poly differential mounts
Suspension & Body
  • MCS 2-way non-remote shocks (rebuilt / upgraded at end of 2020 season by MCS to latest 2-way design)
  • 120Nm/150Nm springs (~680#/850#)
  • Vorshlag camber/castor plates
  • Bimmerworld adjustable rear control arm
  • Adjustable swaybar endlinks
  • Spherical front & rear control arm bushings
  • RTAB limiters
  • Front and rear shock tower reinforcements
  • Front subframe welded reinforcement
  • Rear subframe welded reinforcement kit
  • Rear swaybar welded reinforcement kit
  • Factory X brace
  • BMW LTW Strut bar
Exterior/Aero
  • Custom Wile Motorsport front splitter
  • Motion Motorsport undertray
  • MKAH Motorsports Race diffuser
  • Nine Lives Racing wing
  • Hood vent
  • Headlight and fog light delete
Weight
  • ~2800# with 1/2 tank fuel, ~75# rear ballast
  • Crossweight nearly 50% with ~190# driver
Wheels
  • Three sets of Kosei's potentially available
  • Set 1: 5 HC BFG R1S 235/40R17
  • Set 2: 20 HC BFG R1S 245/40R17
  • Set 3: 40% worn Michelin Pilot Sport 4S 225/45R17
Interior & Safety
  • VSR 4-point rollbar based on TC Kline jig
  • VSR sunroof delete, metal sunroof retained, does not leak
  • Cobra Evolution drivers seat
  • Sparco Rev passenger seat
  • Schroth Flexi 2x2 6-point driver & passenger belts, new for 2020
  • Brey Krause Fire Extinguisher Mount w 2.5# bottle - passenger seat
  • Interior mostly gutted, airbags removed
  • Rogue Engineering steering wheel quick release w Sparco wheel
  • MKAH door cards, stock window internals remain
  • VAC aluminum floor pans
  • Battery kill switch
  • Window net
Re: Feeler: FS 1999 BMW 328is
Post by dtlemoine » Fri Jan 10, 2020 1:30 pm
Just for fun, some more photos...
Post by dtlemoine » Thu Jan 14, 2021 5:23 pm
New kid has arrived and the feeler is still out. Car set 4 SD track records in 2020:
South Oval: 1:11.718
Palmer: 1:45.216
remlap: 1:44.414
WGI: 2:07.881
Photos are old, nothing has really changed aside from new belts on both driver and passenger side. Schroth Flexi 2x2.
Post by Mick » Thu Jan 14, 2021 9:53 pm
It wasn't the car that set those records kid.
Congrats and good luck with the sale.
Post by DanB » Sat Jan 16, 2021 11:11 am
:shock:
Great car, kicks ass for realz, good luck with sale!
Post by dtlemoine » Fri Oct 22, 2021 2:09 pm
This is, of course, still for sale (for the right price, isn't everything??). Updated asking to $19.9k with the new Chris Howard cage, Schroth belts, and Wile Motorsports' 2021 refresh.
Could easily slot in to T60 (good street tires), 70 (Hoosiers), 80 (with ~5 points to spare currently on discontinued R1S'), and of course, stands at the sharp edge of SD.
Could take this over to NASA and run GTS2 or WRL GP2 based on my back of the envelope math. Believe it can run competitive lap times in both. There's probably a decent home for it in SCCA as well, I'm just not familiar with those rule sets.
Post by dtlemoine » Wed Nov 03, 2021 12:15 pm
Pending sale. Car will be staying in the region, but outside of COM. Be on the lookout for a wacky livery running with some of the more "fun" Enduro series...
Re: SOLD
Post by dtlemoine » Thu Nov 04, 2021 11:54 am
Sold
Re: SOLD
Post by dinoracer » Thu Nov 04, 2021 8:25 pm
Congrats on the sale Dave. Looking forward to what the next Lemoine monster is.....
TXBDan
Re: SOLD
Post by TXBDan » Wed Nov 17, 2021 3:06 pm
Congrats! Yeah, what's next?!
Dan Durusky
Mazda RX8
gcranston
Re: SOLD
Post by gcranston » Wed Nov 17, 2021 9:57 pm
Henceforth known as "the Lemoinester".
Graham Cranston
#76 T50 | 2013/15 FT86
