Post
by wizzman » Thu Nov 20, 2014 1:11 pm
***SOLD***
For sale are two sets of Kosei K4R wheels purchased from Tire Rack:
http://www.tirerack.com/wheels/WheelClo ... sort=Brand
The specs are:
15X8
4X100
35mm offset
12.1 lbs
I used these for less than one track season on my Mazda Miata. I HIGHLY reccomend 15X8s if you are considering running a 225 width tire. The only reason I am selling is because Enkei finally came out with 15X8 RPF1s (twice the cost of these). Each set was originally $650 shipped from Tire Rack. Kosei center caps (not pictured) will be included.
$400 for the remaining set
wizzman on Tue Nov 10, 2015 12:16 pm, edited 3 times in total.
Post
by wizzman » Thu Apr 23, 2015 4:11 pm
One set is sold.
I have one set still available at the lowered price above. One wheel has some light scratches on it.
cgreekie
Post
by cgreekie » Wed Jun 10, 2015 10:36 pm
Hi Dave,
Looking at 15s for a track setup but have an issue with my front brake setup being to large for most 15" wheels.
Can you measure the inside diameter of the wheel at smallest point? I need a wheel with 14.2" diameter at least to clear my brakes and this spec is hard to find on wheels.
Thanks Chris,
Post
by wizzman » Sun Jun 14, 2015 9:07 pm
cgreekie wrote:Hi Dave,
Thanks Chris,
I highly doubt you will find a 15" wheel with 14.2" of clearance. The inner rim bows in to some degree on all wheels. These Koseis have some of the best brake clearance I have seen in both width and depth. I measured the smallest part of the inner diameter near the spokes and it was 13.3". You are welcome to swing by and do a test fit.
cgreekie
Post
by cgreekie » Mon Jun 15, 2015 1:02 pm
I think your right. There are a few obscure and expensive wheels that will fit I've found but, most do not.
Thanks for the effort, I think I'll end up with 16s or 17s.
peejay
Post
by peejay » Mon Nov 02, 2015 3:52 pm
Are these still available?
PJ A
1996 Miata
T30 91
Post
by wizzman » Tue Nov 10, 2015 12:16 pm
Sorry- long gone
