Spec-Al
- Forum Newbie
Post
by Spec-Al » Thu Jul 17, 2014 12:45 pm
Was psyched to be able to use paypal for NHMS1, 2 and 3, but getting some error messages since trying it a few times last night. Just wanted it out there if no one else had mentioned it yet.
Code: Select all
Server Error in '/comscc' Application.
Incorrect syntax near '='.
Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code.
Exception Details: System.Data.SqlClient.SqlException: Incorrect syntax near '='.
Source Error:
Line 39: {
Line 40: Utilities.LogError(ex);
Line 41: throw ex;
Line 42: }
Line 43: finally
Source File: d:\hosting\5677599\html\comscc\App_Code\GenericDataAccess.cs Line: 41
Stack Trace:
[SqlException (0x80131904): Incorrect syntax near '='.]
GenericDataAccess.ExecuteSelectCommand(DbCommand command) in d:\hosting\5677599\html\comscc\App_Code\GenericDataAccess.cs:41
EventRegistrationsAccess.GetRegSessionVars(String regID) in d:\hosting\5677599\html\comscc\App_Code\EventRegistrationsAccess.cs:204
CheckoutReview.Page_Load(Object sender, EventArgs e) in d:\hosting\5677599\html\comscc\CheckoutReview.aspx.cs:25
System.Web.Util.CalliHelper.EventArgFunctionCaller(IntPtr fp, Object o, Object t, EventArgs e) +14
System.Web.Util.CalliEventHandlerDelegateProxy.Callback(Object sender, EventArgs e) +35
System.Web.UI.Control.OnLoad(EventArgs e) +99
System.Web.UI.Control.LoadRecursive() +50
System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +627
Version Information: Microsoft .NET Framework Version:2.0.50727.4247; ASP.NET Version:2.0.50727.4252
#345 - Cayman S - T70
Post
by dtlemoine » Thu Jul 17, 2014 4:11 pm
Had the same issue paying for Thompson - I believe Fred is looking in to it.
I was able to pay by credit card with no issues.
boltonite
- Administrator
Post
by boltonite » Thu Jul 17, 2014 5:33 pm
There appears to be a bug using paypal from the MY COM STUFF page (using PayPal at checkout is working) so the PayPal option has been removed from the MY COM STUFF page, you can use paypal at checkout, otherwise you will need to use Visa or MasterCard to pay online via the reg site, until further notice.
Post
by offcamber09 » Fri Jul 18, 2014 5:07 pm
boltonite wrote:There appears to be a bug using paypal from the MY COM STUFF page (using PayPal at checkout is working) so the PayPal option has been removed from the MY COM STUFF page, you can use paypal at checkout, otherwise you will need to use Visa or MasterCard to pay online via the reg site, until further notice.
I had the problem at check out. Just used the CC option with no problem.
