						Post
								by breakaway500 » Sun Jul 13, 2014 7:28 pm
			I see there seems to be some options as far as the tracks layout and direction; they can eliminate one deep 180 turn with an "S" bypass, and can run it clockwise or anticlockwise. Does anyone know what configuration COM will be running?  I was going to preview some in-car Thompson videos and it would be helpful to know the layout/direction that will be used. ( I have been known to take shortcuts first time out..
						Post
								by StephanAlfa » Mon Jul 14, 2014 11:29 am
			I don't think they are looking to get the CLUBHOUSE turn (4) into a option of configurations.
There are two configurations for Thompson: 1.7 mile and 1.5 mile. The difference is in turn 4. Turn 4 (aka "Clubhouse) is the 1,7 mile whereas turn 4a is the shorter 1.,5 mile configuration.
Several items being addressed with Thompson as pointed by some clubs:
* pavement degradation in some turns (6 and 9 I think where is meets with the current oval track
* options for turns 7-8 (Oval) using high bank. Currently they have it sectioned off with cones forcing you do run the flat portion.
* turn 9 pavement leveling: apparently if you go in at the edge of the turn-in point it has some pavement transitions that are  concerning
* narrow pit entrance
I am thinking COM event this coming July 27-28 with be using the 1.7 mile course.
									Stephan de Pénasse - Classroom Instructor -
http://www.comscc.org
- Moderator
						Post
								by jeffw » Mon Jul 14, 2014 12:27 pm
			I was just there for 3 days with SCCA. The pavement was repaired before the vintage races, and it's in great shape. The patches give some good visual references to what was a very bland track.
they added some track-out curbing at the exit of 10, which is really helpful.
						Post
								by breakaway500 » Mon Jul 14, 2014 12:46 pm
			So,clockwise and full course?    Jeff,any in-car vids you wish to share?
- Moderator
						Post
								by jeffw » Mon Jul 14, 2014 8:13 pm
			Not sure if I'll have time to share any video from this weekend, but i have some video from the soft open about a month ago:
						Post
								by breakaway500 » Mon Jul 14, 2014 8:47 pm
			Thanks Jeff. That hairpin clubhouse turn reminds me of the 180 turn at Sonoma.(except no pit in)  The transitions do look rough in the video,but we shall see..
								McMahonRacing
						Post
								by McMahonRacing » Tue Jul 15, 2014 8:30 am
			Try NASA forums in the Northeast section for video ... we ran there a couple weeks back, we tore up plenty of payment esp. club house turn ... if I remember correctly w/ a 3 day event, extra "racer" test time on day # 1 and a full compliment of HPDE I think we only tore up one car and that was in a race, in Turn # 1 ....
						Post
								by breakaway500 » Tue Jul 15, 2014 9:36 am
			I think Thompson will end up paving more runoff at turn one ( like Watkins Glen turn one) It does seem to sneak up on drivers,at least from the videos I have been watching.
     It looks to be an interesting track,surely not a Glen,but it is better than a cow pasture...
						Post
								by brucesallen » Tue Jul 15, 2014 11:15 am
			So Jeff,
Is the grass at Turn 1 the recommended line?
- Moderator
						Post
								by jeffw » Tue Jul 15, 2014 1:39 pm
			Not at all, Bruce.
But you've gotta figure out how to make a pass stick
																			 SEISAN
						Post
								by SEISAN » Tue Jul 15, 2014 3:30 pm
			Jeff,
Did you really mean " A Sticky Pass".
The video helps to get a feel of what to expect.
BB
																			 CP
						Post
								by CP » Thu Jul 24, 2014 8:17 pm
			Thompson is a tight course with no time to relax; you're always turning.  The patches have lots more grip than the original pavement so hunt for them.  My SM was experiencing major understeer issues all weekend.  I found that 15-cycle tires from last season worked much better than new ones.  I also went full stiff on my rear bar and ran the rear tire pressures 6 pounds higher than the fronts.  That got me close to a neutral car by Sunday's races.  The pavement is slick and still leeching oil.
Amenities are few and your best bet for gas is just into MA for cost.  They've got 93 at the track for somewhere close to $5/GAL.  Ice can be purchased at the food stand for $3/bag though I don't know if they'll have that open for your event so don't count on it.  Wifey ate at the golf clubhouse for lunch and said the food is good.  I got a cone from the ice cream stand in the parking lot and it's good too.
						Post
								by breakaway500 » Fri Jul 25, 2014 6:02 am
			Cy,thanks for that update.I was concerned about using old heat cycled "blue" tires,but it sounds like they will be just fine.
						Post
								by StephanAlfa » Fri Jul 25, 2014 9:34 am
			CP wrote:Thompson is a tight course with no time to relax; you're always turning.  The patches have lots more grip than the original pavement so hunt for them.  My SM was experiencing major understeer issues all weekend.  I found that 15-cycle tires from last season worked much better than new ones.  I also went full stiff on my rear bar and ran the rear tire pressures 6 pounds higher than the fronts.  That got me close to a neutral car by Sunday's races.  The pavement is slick and still leeching oil.
I was there this week. A few "edits" if I may:
* Most turns at TMS are off camber at track out.  This may have been one of the reasons for understeer as you apply throttle at the apex to track out.
* Jeff W previously explained tire "graining" (sp?) issue and you have confirmed it as well with the use of "older" tires. Surface is new and in some areas even recently repaved.
* Gas is available at the track, credit card only. 93 was $4.79/gal at the track this past Tuesday
* I agree with your WIfey: Resto food is very good and access is via the clubhouse "tent" (off turn 4) from the track. Need to go over the bridge to get there.
																			 CP
						Post
								by CP » Mon Jul 28, 2014 6:39 am
			We walked the track and there's actually (very little) good camber in every corner, despite what it feels like in the car.  The T3 apex cone/curbing is way off...too late.  The apex is the dirt patch before the curbing begins.
