Parting out my 1985 full race Mustang, but first will offer the entire car for $8500. This is a fox body car with the following parts:
302 engine (all new parts including high nickel iron block, Edelbrock aluminum heads, Dominator intake, Holley carb, MSD ignition, E303 cam, Canton oil pan, est 350-360 hp)
Cobra clutch
Hurst shifter
Tremec TKO500 5-speed transmission
AJE K-member
UPR A-arms
caster/camber plates
QA1 coilovers (single adjustment)
Detachable steering wheel
battery box
S-W gauge set
Aluminum drive shaft
5-lug conversion with Cobra disc brakes front and rear
5-lug hubs with 3 inch studs
SN95 spindles
8.8 rear end with 3.73 gears and new Yukon axles
Kirkey Intermediate race seat (15 inch) plus Kirkey passsenger seat
G-Force 5-pt belts
Jazz fuel cell
6-point cage
new glass
Fiberglass hood
window net
welded frame rails
Enkei PF01 18x9.5 aluminum wheels (2 sets)
285/30x18 BF Goodrich R-1 DOT tires (almost new) plus roller tires
I bought this car from a racer in NJ right after its construction and then did the 5-lug conversion, brakes, suspension, and engine upgrades. The car is structurally sound in the floor pans and rails. The fender arches have been hacked to get tire clearance, but flares could fix that. Car has run a 2:21+ lap at Watkins Glen and has been extremely reliable. I have run this car with COM for the past few years, but does not have a lot of track time. Car is located in Rouses Point NY (north of Burlington, VT). Best time to call is at night at 518-206-4050. Call with any specific questions. If you are interested in specific parts, call me, or you can text me at 802-999-8768. If car does not sell complete, I will start parting for those interested in parts.
Picture of car before new wheels:
http://i789.photobucket.com/albums/yy17 ... 2149521607
I can send more pics to anyone interested.
1985 Mustang Full Race Car or Parted Out
rousespointer
Re: 1985 Mustang Full Race Car or Parted Out
Have you started to part this out yet? I would be interested in the Tremec and the wheels what offset are the wheels. Can you please advise what the offset is?
rousespointer
I have not started on parting out the car, as it would be a lot less labor to sell the whole car. I will provide an update in the next few weeks. I will check on the offset of the wheels...I think they are marked on the inside (maybe +35 but just a guess). I bought the wheels through Dave Lopilato's business a few years ago.
I'm also interested in the wheels, tires, as well as the hubs n' studs.
Steve T.
Steve T.
2007 Shelby GT, BFG R1s 275/35/18, Agent47 brake ducting, Vorshlag brake lines, Cobra Sebring, Race Roll Bar, Carbotech brake pads, FR3 handling Pack, FR Power Pack.
fb.com/trinkatiseracing.com
