We discovered a pretty good crack near the lower control arm on the driver's side on Julie's car. Anyone got a 94-97 subframe sitting around?
-j
Looking for 94-97 miata front subframe
Re: Looking for 94-97 miata front subframe
you can't check it for square and then weld it then if needed weld a little gusset ?
i'm thinking it would be cheapper and end up being stronger too .
