ariel atom kicked out of top position on top gear track
just saw it on top gear.
Rebecca
Rebecca
Re: ariel atom kicked out of top position on top gear track
did not want to give it away but ok I will. It was a Pagani Huayra. It was a pretty entertaining episode (at least the Huayra and rally racing in Wales in the Fastest Bentley ever). That was impressive. The part about the worlds smallest car was not very interesting. Reasonably priced car was pretty good. Slowest time ever (but with good reason - snow and slush on track).
Rebecca
Rebecca
not 4 wheel drive.
Rebecca
A dab of brakes as he passes the tires, presumably with his left foot, or the middle one.n1gzd wrote:
not 4 wheel drive.
Rebecca
LMAO!
I need to borrow a million ... or so ...
VEHICLE TYPE: mid-engine, rear-wheel-drive, 2-passenger, 2-door coupe
BASE PRICE: $1,070,500
ENGINE TYPE: twin-turbocharged and intercooled SOHC 36-valve V-12, aluminum block and heads, port fuel injection
Displacement: 365 cu in, 5980 cc
Power: 720 hp @ 5800 rpm
Torque: 738 lb-ft @ 2250 rpm
TRANSMISSION: 7-speed automated manual
DIMENSIONS:
Wheelbase: 110.0 in
Length: 181.3 in
Width: 80.2 in Height: 46.0 in
Curb weight: 3200 lb
PERFORMANCE (C/D EST):
Zero to 60 mph: 3.0 sec
Zero to 100 mph: 6.4 sec
Standing ¼-mile: 10.9 sec
Top speed: 224 mph
DIMENSIONS:
Wheelbase: 110.0 in
Length: 181.3 in
Top speed: 224 mph
custom engine from AMG.
MPG? Towing capacity?
Watched it last week. As Jeremy said, the car is great but the name is stupid (and unpronounceable by most people).
Fuel consumption: 10 mpg city,14 mpg highway (EPA testing)
Towing capacity: Let me know if you find a place to mount the tow bar.
Its ok I knew I was going to hear about at work. When I found out pretty much every episode was on streaming netflix I watched probably 6 seasons over the course of 3 sick days.n1gzd wrote:did not want to give it away but ok I will. It was a Pagani Huayra.
you have to ask your self this ?
if i bought a atom and took the 200K i save by not buying the pagani huayra could i make the atom 2 seconds faster a lap ?
as long as you tighten the bolts to your upper comtrol arms you could ! sorry mark did i say that out loud ?
I think that you would save a lot more than $200k.
Rebecca
Rebecca
yes i looked up the price it's a one million dollar car ?
but i still say even for the little old 200K you could make the atom as fast !
then with the deferents of the price of the atom and the 200K INTO IT I WOULD JUST GO BUY THE cheap Zonda .
