Looks like T50 will be merry! The setup will be either:Dtangard wrote:A non-miatadtlemoine wrote: I'm currently deciding between T50 and T60. Will be either a near-stock E36 M3 on street tires, or something comparable to Nick F.'s setup.! I hope you choose T50. The more the merrier.
1) 62.5 (base points) - 5 (200+ lbs overweight) - 2 (tire width 225) + 3 (Nitto NT-01) +1 (Koni single adjustable shocks, OEM sways) = 59.5
2) 62.5 (base points) - 5 (200+ lbs overweight) - 2 (tire width 225) + 3 (Nitto NT-01) +1 (UUC swaybars, Non-adjustable shocks) = 59.5
and in the rain...
Tire width goes to 245 and compound changes to a Star Spec for net 0 points from the above setups.
Looks like it should be a pretty solid setup in the dry, especially at some of the longer tracks. I think I'll have a tough time keeping up with the Miatas at NHMS in the dry, and given the limited flexibility on tires, anytime it rains at any of the tracks.
Folks who run E36's - more bang/buck from a Bilstein sport shock with UUC sways & OEM springs, or keep the Koni's and OEM sways? I've read mixed reviews on using Bilstein Sports with OEM springs, as they aren't always a great match for each other. Worried the setup could end up being a bit too twitchy.
