NHMS One Videos
Re: NHMS One Videos
Post by jeffw » Wed Jun 06, 2012 10:52 am
dinoracer wrote:
escortracer wrote:Tom and I running some laps I think I went just a little over the white line in 6.
Bob, I like your line in the oval better than mine - probably good for 2-3 car lengths beginning to end. When I was behind you, you didn't brake going in- maybe a little lift that's all? I see a couple other places I need to work on too. Thanks!
Tom: If you look at the datalogger plot I posted in this thread the first lift off the throttle is for turn 1. I'm lifting to about 50% throttle for about 200'. I suspect I should be lifting for less time, but it's a hard thing to convince myself of :-)
If you have good tires, you shouldn't need to brake and the lift should be small :-)
Re: NHMS One Videos
Post by Stynger » Wed Jun 06, 2012 12:16 pm
Tom, are you braking hard into 3? Looks like you're on the brakes well before the first cone all the way to after turn in.
Do your brakes suck that bad? :shock: Are you riding them? Old Mustang habit?
Most are on the gas before turn in.
Re: NHMS One Videos
Post by dinoracer » Wed Jun 06, 2012 10:36 pm
Thanks Les. Brakes are good; I think I'm resting my foot on the pedal a bit early, and braking for too long.... And yeah, the old Mustang habits are tough to break... but having a car that turns when you want it to is nice.
Re: NHMS One Videos
Post by WillM » Thu Jun 07, 2012 9:34 am
Tom,
Don't be too worried about dragging the brake around T3. I have it on pretty good authority that the SPC class record was set by a Miata that typically trail-brakes at T3. ;)
Then again, that guy's rear wing is a lot bigger than yours. :lol:
savage217
Re: NHMS One Videos
Post by savage217 » Fri Jun 08, 2012 9:18 pm
Holy oil! Can't believe he kept going after he put the wipers on and it smudged the entire windshield. I would have pitted.
Nick DeRosa #305
Re: NHMS One Videos
Post by paultg » Sat Jun 09, 2012 8:04 am
savage217 wrote:Holy oil! Can't believe he kept going after he put the wipers on and it smudged the entire windshield. I would have pitted.
Nick, i agree. I just didn't realize it was oil and tried to clear it a few times making it worse. By the time I got onto the front straight I slowed down realizing it wasn't getting any better and went around to pit.
