question about trailering
n1gzd
Post by n1gzd » Wed May 02, 2012 10:51 am
I think that I should put my Miata tranny in Neutral and set the ebrake. Is this correct?
thanks,
Rebecca
Re: question about trailering
Post by Chrispy » Wed May 02, 2012 11:07 am
That's what I do.
Sometimes the straps loosen up a little bit in the first 50-100 miles of towing so it is good to have the brake set to prevent the car flopping about under acceleration and braking. Doesn't hurt to take a pit stop to check the straps either :)
naschmitz
Post by naschmitz » Wed May 02, 2012 11:26 am
Talk to Jeff W :D
Bert Schmitz
Post by TroyV » Wed May 02, 2012 12:08 pm
I would appear that one cannot live down Knight Rider-ing one's own car. ;)
cfossum
Post by cfossum » Wed May 02, 2012 12:17 pm
First gear and e-brake for me.
MiataSteve
Post by MiataSteve » Wed May 02, 2012 12:25 pm
Parking brake and neutral is how I tow. Somewhere I "heard/read" that trailering in gear could put stress on the drive line...??
Post by paultg » Wed May 02, 2012 12:26 pm
I've never towed a car via trailer, but why would you want to leave it in neutral? I think I'd treat it just like any other time I park it.
Post by Chrispy » Wed May 02, 2012 12:36 pm
paultg wrote:I've never towed a car via trailer, but why would you want to leave it in neutral? I think I'd treat it just like any other time I park it.
Because you are moving and is a separate mass to the trailer the car jostles back and forth a little which might bang things around in the drive-train. I use 5 straps on my car so I'm not worried about it going anywhere. I think the risk of transmission damage is pretty slight so if you prefer the extra security you can put it in gear. You can even use wheel chocks.
n1gzd
Post by n1gzd » Wed May 02, 2012 12:37 pm
I too had heard that it would stress the driveline which is why I asked about it.
Rebecca
Post by Mick » Wed May 02, 2012 12:47 pm
I leave mine in neutral with the e-brake on too.
My rationale is that if the car moves fore and aft slightly while towing, you have dry pistons rubbing on the cylinder walls. May be paranoid, but it helps me sleep at night.
Post by breakaway500 » Wed May 02, 2012 1:28 pm
My tow straps always loosened up "magically" even with the parking brake applied,but since chocking the front and rear of one wheel..they stay tight. I use the rubber blocks..about 15 bucks each. Image
Post by Mick » Wed May 02, 2012 1:42 pm
How do you keep the chocks in place?
n1gzd
Post by n1gzd » Wed May 02, 2012 1:54 pm
that is a good question. The large rubber ones are very heavy but I woudl thinkthat even those could move a little.
rebecca
Post by breakaway500 » Wed May 02, 2012 2:57 pm
They have never moved.The rubber ones seem to grip the floor of the trailer quite well.Even after an emergency panic stop( :shock: ) coming home from NHMS last year,the chocks were snug and in place. I had tried the plastic ones,but they did not work. I suppose you could bungie them together,but I haven't had to.
SEISAN
Post by SEISAN » Wed May 02, 2012 4:12 pm
Since my vehicle weighs in at 3100 lbs and and I have it on an open trailer I use straps with hooks that attach to the frame. I cross the straps from side to side. I also put a strap through my rear rims and slide it under the trailer and tighten it. It may be over kill but I am assured the car will not move. I keep it in 1st with the EM brake on. The car may bounce up and down but never sideways.
Users browsing this forum: Ahrefs [Bot], Majestic-12 [Bot] and 1 guest
