FS: 91 Miata Drivetrain/Parts
Post by paultg » Tue Apr 03, 2012 9:41 pm
Everything listed below has over 100K miles, but under 150K. Unless noted otherwise everything is out of my '91 Miata which I have owned since Sept. of 2008. Prices are based off online prices from http://www.planet-miata.com/index.php?section=31630995 , reduced quite a bit from what is on their site. But, make me an offer too. Better deal for taking lots of stuff. :)
4:30 Open Rear Differential - $125
Miata drive shaft: $40.00
Miata PPF ('94): $50.00
Miata Rear Subframe ('94): $50
Miata 1/2 shaft (Axle) driver & passenger side: $20 each
Miata front upper control arms with ball joints - driver and passenger side: $40 each
Miata front lower control arms - driver and passenger side: $40 each
Miata rear lower control arms - driver and passenger: $40 each
Miata rear upper control arms - driver and passenger: $40 each
Miata rear wheel knuckle, hubs with bearings - driver and passenger: $60 each
Miata suspension (shocks, springs, top hats, all assembled for each corner): $25 each
Re: FS: 91 Miata Drivetrain/Parts
Post by paultg » Tue Apr 03, 2012 9:50 pm
Also, car will be out of storage this week, so if you wanted to drive it you can (so long as you don't drive it like Nate H :o ). I live in Londonderry, Nh.
Everything but the motor and transmission is already out of the car and available.
iamrazor
Post by iamrazor » Wed Apr 04, 2012 9:44 am
dibs on the rear LCA's!!!
#29 T40 Miata
Post by paultg » Sat Apr 21, 2012 2:14 pm
updated list, motor and transmission are sold.
