work is slow !
Re: work is slow !
Just spray the car with rhino liner. You'll never have to worry about stray cones or offs again, plus it might be heavy enough to keep those rear wheels down in turns.
Re: work is slow !
Home Depot, really?!?! Wow, I had no idea you are so wealthy.Mark Swinehart wrote: Do I need to bring some rattle spray paint cans from Home Depot?
Common folk (the 99%!) buy their paint at Harbor Freight!
Re: work is slow !
Sam's buying - $ isn't a consideration or issue!!
Re: work is slow !
home depot is only 2 miles away were harbor freight is 20 miles away . i'm just trying to save sam some money on gas . i like the bed liner idea ! it may work like the dimples on a golf ball ????
Re: work is slow !
David –
Thanks for the hospitality; it was nice to see you today. Too bad I missed Carl and his new truck.
I forgot to ask when on Tuesday would be good for me to come and get the finished job?
Mark
Mark
Re: work is slow !
mark bad news the left frame rail is pushed down about 3/4 of an inch . so is tuesday night going to be ok for you to pick up the car ???? its to bad you missed Carl his newsed (new/used) truck is nice ! i have to detail it and repair the clear coat pealing off the fenders , dent in the left bed side and the rear bumper . when i'm finished it will look like a new truck .
Re: work is slow !
No problem, I can give you some extra time.
See you Wednesday morning instead
Re: work is slow !
mark it seams that some were at some time the info label was taken off the door of the car . it has the color code and all the other crap i need . what year is the car ?????
Re: work is slow !
That's exactly what I wanted to hear!962porsche wrote: when i'm finished it will look like a new truck .
Good to see you today, Dave.
-Carl
Re: work is slow !
It's the same thing David told me, "Your car will look like new!"
Re: work is slow !
mark i found a way to remove the 600 lbs you wanted from your car . just don't hit any thing !!!!!
Re: work is slow !
That's the greatest idea I ever heard. Get ready for a new look for the Frankenspec.TroyV wrote:Just spray the car with rhino liner.
Re: work is slow !
Carbon fiber - replace everything you can with it.
Thanks David
Thanks David
Re: work is slow !
Is "Bondo" carbon fiber
Re: work is slow !
DanDarcy wrote:Is "Bondo" carbon fiber![]()
NO just what i mix the bodyfiller on is !!!
