savage217
Post
by savage217 » Sun Oct 16, 2011 12:23 am
I finally started pulling my engine out of the car. Took my intake manifold off and this is what was discovered.
Tomorrow I plan on finishing the engine removal. I do not expect I will have the head off until sometime this week. I found a local engine for a killer deal so I should have the car back and running within 3 weeks I would think. Cant wait to see the bottom end.
Nick DeRosa #305
Post
by dinoracer » Sun Oct 16, 2011 8:06 am
Ouch!
I think a lot of us have BTDT- Part of the fun of driving "Flat-out"
Good plan to get it back together before the snow flies; The first event of 2012 sometimes arrives while there's still snow on the ground in front of the storage garage, and pushing cars thru mud to get them to where they can be worked on sucks
savage217
Post
by savage217 » Sun Oct 16, 2011 11:31 pm
Nick DeRosa #305
Post
by brucesallen » Mon Oct 17, 2011 11:03 am
That's what Nitromethane will do.
Post
by 6PAK72 » Mon Oct 17, 2011 2:29 pm
OUCH.
So sorry.
savage217
Post
by savage217 » Wed Oct 19, 2011 12:59 am
Nick DeRosa #305
Post
by breakaway500 » Wed Oct 19, 2011 7:24 am
I have never seen a retainer fail in that manner before. Wow. That is bad luck for sure. Damn,that piston crown is nasty!
Post
by Chrispy » Wed Oct 19, 2011 7:34 am
Ouch, poor piston.
Post
by brucesallen » Wed Oct 19, 2011 12:23 pm
Chrispy wrote:Ouch, poor piston.
JB Weld can fix it.
Post
by dinoracer » Wed Oct 19, 2011 1:51 pm
You'll need to sleeve that cylinder for sure. Unless there's something particularly valuable about that block, I'd replace it with a low-mile junkyard one.
savage217
Post
by savage217 » Wed Oct 19, 2011 5:10 pm
I am planning on JB welding the piston back together and smoothing it out. I will just wire brush the cylinder walls and then throw it all back together after wiping it down with a clean paper towel. Should do well.
I bought a used s52 out a 51k mile rear ended car. It was still in the car so I was able to a compression test and oil pressure test, etc. It all came back positive so I am buying it either tomorrow night or sunday sometime.
Nick DeRosa #305
Post
by brucesallen » Thu Oct 20, 2011 12:31 pm
savage217 wrote:I am planning on JB welding the piston back together and smoothing it out. I will just wire brush the cylinder walls and then throw it all back together after wiping it down with a clean paper towel. Should do well.
As long as you use lots of STP.
savage217
Post
by savage217 » Thu Oct 20, 2011 11:58 pm
Nick DeRosa #305
Users browsing this forum: Amazon [Bot], Baidu [Spider] and 1 guest
