1.6 Miata AC removal ??
Post by 6PAK72 » Sun Jan 16, 2011 7:27 pm
I'm about to pull the AC from Smurf, and someone told me there's a pulley assembly that is needed to replace the compressor.
1. Anyone have one to sell? Or, know where I should buy one?
2. Anyone done this, and have hints I need to know - other than purging the unit, which I know about?
Re: 1.6 Miata AC removal ??
Post by breakaway500 » Sun Jan 16, 2011 8:07 pm
Can't you just run a shorter belt to run the power steering? That is what I did when I eliminated my a/c compressor.The ps pump has the adjustments for belt tension,so it's no biggie.Shorter belt,snug it up and good to go. :D I'll be surprised if there is any refrigerant in that old an a/c system. You can depress the schrader valve (in the service port) for a second to see before you open the system. Take all the refrigerant lines off,and remove the receiver/drier canister.You could put little plastic plugs (or electrical tape) over the open ends of the evaporator core line ends on the firewall,to keep stuff out,in case you ever want to reinstall the a/c .Take the condenser out.Done!
Dtangard
Post by Dtangard » Sun Jan 16, 2011 10:37 pm
When I removed my ac (1.8L) I just replaced the belt with a shorter one. I'd be surprised if the 1.6 is any different. Purging the system was fun...
#01 T40
Post by Stynger » Sun Jan 16, 2011 10:55 pm
Pull the condenser and replace it with a stock plastic duct from Mazda made for the Miatas without A/C.
Post by 6PAK72 » Mon Jan 17, 2011 7:50 pm
Thanks, all.
If it warms up from -7 this weekend...
Post by Stynger » Mon Jan 17, 2011 10:07 pm
FWIW the adjustable pulley assembly is needed when keeping the A/C but pulling the P/S.
The belt for just the P/S is available from Mazda or NAPA.
CP
Post by CP » Tue Jan 18, 2011 3:47 pm
Or yank the power steering while you're at it and eliminate that belt altogether. Spec Miatas with power steering are a rare sight at impound on race days. I pulled the AC compressor bracket that's bolted to the side of the block too.
Post by paultg » Tue Jan 18, 2011 11:58 pm
As others have said just use the shorter ps only belt. That's what I did on my 1.6l.
I broke the compressor off the motor (leaving the engine to compressor bracket) cause it was quicker. I've read if you pull the bracket you may need a shorter bolt into the engine block (or you'll have an oil leak), but I can't confirm that, just what I read on miata.net
Post by Stynger » Wed Jan 19, 2011 12:27 am
paultg wrote: I've read if you pull the bracket you may need a shorter bolt into the engine block (or you'll have an oil leak), but I can't confirm that, just what I read on miata.net
That's true.
